Warning message
Cisco 888 G.SHDSL Router - Dial issues
Jun 6th, 2012
Hope someone can help with this, I'm struggling with configuring the above router with a SDSL connection in the UK.  To be honest this is the first time I've configured SDSL on Cisco products but I have configured ADSL in the past.
Basically everytime I try to ping an IP address, I get the error "Di1 DDR: Cannot place call, no dialer string set." even though i have specified dialer pools in my config and added it to the (I assume) correct interface.
Show cmds for the DSL interface show this to be up and in sync, so does the ATM 0 interface but dialer shows its up but has not gained an IP address from the ISP over PPP but I guess this must be because the DDR issue.
Config is below,  any help would be gratefully received.
Thanks!
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
no ip mfib
ip cef
no ipv6 cef
controller DSL 0
mode atm
dsl-mode shdsl symmetric annex B
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 10.0.0.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
interface Dialer1
ip address negotiated
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname *****************
ppp chap password 0 **************
ppp pap sent-username ************ password 0 *********
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 10 permit 10.0.0.0 0.0.0.255
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
login
transport input all
end
