Per-Tunnel QoS on a DMVPN Tunnel Not Working.
Jun 6th, 2012
Hello, I am trying to get per-Tunnel QoS working on one of my Hub tunnels, and believe to have the configurations correctly, but when I do "show ip nhrp group-map" I get NONE. I am running a MPLS-VPN network and this router has multiple DMVPN Tunnels with different VRFs. I am not running QoS on the other tunnels.
router#show ip nhrp group-map
Interface: Tunnel1
NHRP group: testgroup
  QoS policy: test-QoS
  Tunnels using the QoS policy: None
here is my config
interface Tunnel1
ip vrf forwarding test
ip address 172.16.1.1 255.255.255.240
no ip redirects
ip mtu 1376
ip nhrp authentication test
ip nhrp map multicast dynamic
ip nhrp map group testgroup service-policy output TEST-QoS
ip nhrp network-id #####
ip tcp adjust-mss 1200
load-interval 30
tunnel source Loopback1
tunnel mode gre multipoint
tunnel key #####
tunnel vrf test_internet
tunnel protection ipsec profile IPSECPROFILE shared
Router Version
(C7200-ADVENTERPRISEK9-M), Version 15.0(1)M3
I understand that I could do qos pre-classify in the tunnel and then do a service policy on the physical interface, but the question I have is why does it say " Tunnels using the QoS policy: None " when I configured a qos policy on the tunnel interface? Is this a bug?
Thank you for your help!
Marcin Latosiewicz Wed, 06/06/2012 - 23:12
  • Cisco Employee,
Ray,
There could be multiple reasons for it not to function, the config on hub seems just fine, we'd need to inspect the spokes and check (most likely) in debugs if correct group is being sent from spoke.
Also coexistance of other service-policy etc etc.
The feature is quite simple (some level of simplification), spoke says he is in group X when registering, hub assigns this NHRP mapping a service-policy.
M.
ray_nuncio Thu, 06/07/2012 - 07:28
Thanks for the reply Mercin,
Yes, the spoke does have the correct group name and the Hub Tunnel does recongize the spoke and puts the spoke in the right group. There is no service-policy on the physical interface for the hub tunnel. I do have a service policy for the spoke on the physical interface.  There is only one spoke on that tunnel.
Related Content
