CISCO IP Phone CP-6921 display unable to setup conference when use to conference
Jun 6th, 2012
Dear All,
We are newbie ini Cisco Unified Communication Manager and Cisco IP Phone-6921 IP Telephony.
We have success register Cisco IP Phone CP-6921 to Cisco Unified Communication Manager and make call between CP-6921.
We have problem when we want use conference feature, when we have active call with another CP-6921 and then we press conference button on CP-6921 to make a new call.
After our call is answered, we press soft button with conference display on our CP-6921 but on out CP-6921 display message "Unable to setup conference"
Note:
CP-6921 using SIP 9.1.1.0. for this time using 1 line
Cisco Unified Call Manager system version: 8.5.1.10000-26 (demo mode)
On Cisco Unified Call Manager Administration - Device - Phone, for CP-6921 (CP-6921.png, CP-6921_1.png and CP-6921_2.png)
Phone button template:Standard 6921 SIP
Common Phone Profile: Standard Common Phone Profile
Presense Group: Standard Presence Group
Device Securoty Profile: Cisco 6921 - Standard SIP Non-Secure Profile
SIP Profile: Standard SIP Profile
For Another configuration we use Default
Our question:
- How to make line2 on CP-6921 using same directory number at line1?
- What cause CP-6921 cannot use for conference? How to solve it.
We hope you can help us to solve it.
Thanks For Your Attention
Overall Rating: 4 (1 ratings)
Jaime Valencia Wed, 06/06/2012 - 21:55
  • Cisco Employee,
  • Hall of Fame,
    2011
You can't, at most you can configure the same DN in a different partition and then configure CFB/CFNA for cascading.
For conference check your MRGL and make sure there's a CFB in there
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
internet_pratama Thu, 06/07/2012 - 02:14
Dear javalenc,
Thanks for information that you give to us. We have check MRGL (Media Resource Group List) and CFB (Conference Bridge) not in list.
On Media Resource > Conference Bridge, We found 2 list in Conference Bridge with status and ip address "unknown"
We want to excuse if we wrong meant MRGL as Media Resource Group List and CFB as Conference Bridge, because this is first time we configure Cisco Unified Communication Manager
Our question:
How to setting confrence using Cisco Unified Communication Manager that can use for CP-6921?
We hope you can give us information about it
Jaime Valencia Thu, 06/07/2012 - 06:14
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, you got the MRGL and CFB correct. You'll see we abbreviate a lot of stuff so you need to get used to it.
Start by going to serviceability and
A) make sure IPVMS (IP Voice Media Streaming) service is running, if not, enable it and start it
B) If it's running try restarting it.
C) Try resetting the CFBs
That's the service that handles the CFB.
java
internet_pratama Fri, 06/08/2012 - 01:32
Dear Javalenc,
Thanks for information that you give to us. We have checked IPVMS and it by default isn't activated. We have activate IPVMS and now CFB has status registered.
We have try make conference call use device CP-6921 like this:
1. Call another CP-6921 (ext:1001). After another CP-6921 with ext:1001 answer, we press Conference button on CP-6921
2. Call another CP-6921 (ext:1002). After another CP-6921 with ext:1002 answer, we press softbutton with display Conf
The result: Conference Call ended
We have try create MRG (media-conf) and then add MRG to MRGL (conference-test), attach MRGL to device - Phone (
at Media Resource Group List section)
. The result is same as before (Conference Call ended)
If we check on Line1 of CP-6921, we found like this
" Multiple Call/Call Waiting Settings on Device SEP2C542DE91DA4
   Maximum Number of Calls and Busy Triggers per Line are:
   Maximum Number of Calls2
   Busy Trigger
Our Question:
What is missing in our configuration?
We hope you can help us for this.
Ayodeji Okanlawon Fri, 06/08/2012 - 02:20
  • Cisco Designated VIP,
    2017 IP Telephony
Try and change the busy trigger on the phone to 2
Please rate useful posts
"I am complete in God, God completes me"
internet_pratama Fri, 06/08/2012 - 04:26
Dear Aokanlawon,
Thanks for information that you give to us. We have look at CUCM Device-Phone and we cannot change busy trigger on CP-6921 because it can't edit.
Note: We use CUCM 8.5.1
         CP-6921 SIP9.1.1.0
Our question:
How to edit busy trigger on CP-6921?
Thank For Your Attention
julien.lefloch Tue, 06/12/2012 - 01:02
SIP load 9.2.2 for 69xx allows you to change the Max Call & Busy Trigger parameters. This way, your conferences will work.
Regards.
internet_pratama Wed, 06/13/2012 - 03:41
Dear Julien.lefloch,
Thanks for information that you give to us. We will try download SIP 9.2.2.2 for 69xx as your suggest
internet_pratama Tue, 06/19/2012 - 02:32
We want give you information that we have upgrade sip for 6921 on CUCM from 9.1.1 to 9.2.4.3. After CP-6921 using SIP firmware 9.2.4.3. We check on CUCM Device>Phone and find that Max Call & Busy Trigger parameters still cannot edited.
We want give you information that conference on CP-6921 can work after we change System > Server from name to IP Address. After using IP Address on Server, Conference Bridge status registered.
internet_pratama Tue, 06/19/2012 - 02:34
Dear Javalenc,
We have associate Conference Bridge on MRG, assoiciate MRG to MRGL and then using MRGL on Device Phone. After we do it, CP-6921 can use for conference.
Thanks For Your Attention and Help
Related Content
