Dynamic Configuration Tool
Jun 7th, 2012
Morning all,
Can anyone tell me if this is still a solution Cisco give? If you browse to
https://apps.cisco.com/qtc/config/html/configureHomeGuest.html you cannot chose routers etc. What i am doing is just trying to see what modules will fit into a certain type of gateway etc. This tool doesnt appear to work with any browser at all..
Any help would be great!
Overall Rating: 5 (5 ratings)
Davidwagman1 Thu, 06/07/2012 - 15:31
  • Gold, 750 points or more
It's working for me, but the newer CCW seems to work better. Check your java...
For CCW, check out cisco.com/go/CCW them click on configuration.
Carl.Mayne-Wheeler Fri, 06/08/2012 - 04:17
Hello David,
I have tested Java and all appears fine. Are there any settings that need to be changed? I remember years ago having to do something to the browser when downloading some IOS, but I cannot find these settings anywhere...
Thanks again..
acampbell Fri, 06/08/2012 - 05:40
  • Green, 3000 points or more
It does not work to well or me either as GUEST.
However if I drop the search to PRODUCT FAMILY
wait a second or 2 then from the RHS pick say Cisco 3900 it seems to be OK.
Alex.
Please rate useful posts.
Davidwagman1 Fri, 06/08/2012 - 05:46
I think this is the info you're looking for as far as browser settings:
http://www.cisco.com/web/Downloads/SDS/Software_Downloads/FAQs.html#faq8
As I stated above, the dynamic config tool is on its way out... Check out the configuration tool in CCW, it seems much more stable, if you have access.
Please rate helpful posts.
Carl.Mayne-Wheeler Fri, 06/08/2012 - 06:09
Checked that David, the browser seems to be set. Wonder if this is a policy issue on the laptop...
Have you got the direct url for the config tool in CW, I couldnt find that.
Cheers again!
Davidwagman1 Fri, 06/08/2012 - 07:37
Glad to hear your in and working.
Take care
Related Content
