VPLS BGP Signaling between ASR9K & Junos
Jun 7th, 2012
I have configured VPLS bgp signaling between ASR & Junos the VPLS  connection from Junos side indicate it’s up without any problem but from ASR side it’s down
The following output form Junos & ASR
RP/0/RSP0/CPU0:IGW-LON-1#show l2vpn bridge-domain bd-name MPLSL2VPN
Thu Jun 7 18:56:38.028 UTC
Bridge group: MPLSl2VPN, bridge-domain: MPLSL2VPN, id: 0, state: up, ShgId: 0, MSTi: 0
Aging: 300 s, MAC limit: 4000, Action: none, Notification: syslog
Filter MAC addresses: 0
ACs: 1 (1 up), VFIs: 1, PWs: 1 (0 up), PBBs: 0 (0 up)
List of ACs:
   Gi0/0/0/0, state: up, Static MAC addresses: 0
List of Access PWs:
List of VFIs:
   VFI L2VPN
     Neighbor 192.168.255.3 pw-id 2, state: down, Static MAC addresses: 0
RP/0/RSP0/CPU0:IGW-LON-1#show l2vpn bridge-domain bd-name MPLSL2VPN detail
Thu Jun 7 18:56:44.522 UTC
MAC learning: enabled
MAC withdraw: enabled
   MAC withdraw for Access PW: enabled
Flooding:
   Broadcast & Multicast: enabled
   Unknown unicast: enabled
MAC aging time: 300 s, Type: inactivity
MAC limit reached: no
MAC port down flush: enabled
MAC Secure: disabled, Logging: disabled
Split Horizon Group: none
Dynamic ARP Inspection: disabled, Logging: disabled
IP Source Guard: disabled, Logging: disabled
DHCPv4 snooping: disabled
IGMP Snooping profile: none
Bridge MTU: 1500
MIB cvplsConfigIndex: 1
Create time: 04/06/2012 08:00:37 (3d10h ago)
No status change since creation
List of ACs:
   AC: GigabitEthernet0/0/0/0, state is up
     Type Ethernet
     MTU 1500; XC ID 0x840001; interworking none
     Flooding:
     Storm Control: disabled
     Statistics:
       packets: received 111042690, sent 19
       bytes: received 6662562344, sent 1562
     Storm control drop counters:
       packets: broadcast 0, multicast 0, unknown unicast 0
       bytes: broadcast 0, multicast 0, unknown unicast 0
     Dynamic ARP inspection drop counters:
       packets: 0, bytes: 0
     IP source guard drop counters:
List of Access PWs:
List of VFIs:
   VFI L2VPN
     VPN-ID: 2, Auto Discovery: BGP, state is Provisioned (Service Connected)
     Route Distinguisher: 65555:800
     Import Route Targets:
       65555:800
     Export Route Targets:
       65555:800
     Signaling protocol: BGP
     Local VE-ID: 2 , Advertised Local VE-ID : 2
     VE-Range: 10
     PW: neighbor 192.168.255.3, PW ID 2, state is down ( all ready ) (Transport LSP Down)
       PW class not set, XC ID 0xfffc0002
       Encapsulation MPLS, Auto-discovered (BGP), protocol BGP
       PW type VPLS, control word disabled, interworking none
       PW backup disable delay 0 sec
       Sequencing not set
         MPLS         Local                         Remote
         Label       16015                         262210
         MTU         1500                           unknown
         Control word disabled                       disabled
          PW type     VPLS                           VPLS
         VE-ID       2                             1
        MIB cpwVcIndex: 4294705154
       Create time: 07/06/2012 11:52:11 (07:04:32 ago)
       Last time status changed: 07/06/2012 11:52:11 (07:04:32 ago)
       MAC withdraw message: send 0 receive 0
     VFI Statistics:
       drops: illegal VLAN 0, illegal length 0
show vpls connections instance MPLSL2VPN-INTER-AS extensive
Layer-2 VPN connections:
Legend for connection status (St)
EI -- encapsulation invalid     NC -- interface encapsulation not CCC/TCC/VPLS
EM -- encapsulation mismatch     WE -- interface and instance encaps not same
VC-Dn -- Virtual circuit down   NP -- interface hardware not present
CM -- control-word mismatch     -> -- only outbound connection is up
CN -- circuit not provisioned   <- -- only inbound connection is up
OR -- out of range              Up -- operational
OL -- no outgoing label         Dn -- down
LD -- local site signaled down   CF -- call admission control failure
RD -- remote site signaled down SC -- local and remote site ID collision
LN -- local site not designated LM -- local site ID not minimum designated
RN -- remote site not designated RM -- remote site ID not minimum designated
XX -- unknown connection status IL -- no incoming label
MM -- MTU mismatch               MI -- Mesh-Group ID not availble
BK -- Backup connection         ST -- Standby connection
PF -- Profile parse failure     PB -- Profile busy
RS -- remote site standby       SN -- Static Neighbor
Legend for interface status
Up -- operational
Dn -- down
Instance: MPLSL2VPN-INTER-AS
Local site: 1 (1)
   Number of local interfaces: 1
   Number of local interfaces up: 1
   IRB interface present: no
   ge-11/0/1.431
   lsi.1049371         2         Intf - vpls MPLSL2VPN-INTER-AS local site 1 remote site 2
   Label-base       Offset     Size Range     Preference
   262209           1         8     8         100
   connection-site           Type St     Time last up         # Up trans
   2                         rmt   Up     Jun 7 14:55:39 2012           1
     Remote PE: 192.168.106.201, Negotiated control-word: No
     Incoming label: 262210, Outgoing label: 16015
     Local interface: lsi.1049371, Status: Up, Encapsulation: VPLS
       Description: Intf - vpls MPLSL2VPN-INTER-AS local site 1 remote site 2
   Connection History:
       Jun 7 14:55:39 2012 status update timer
       Jun 7 14:55:39 2012 loc intf up                 lsi.1049371
       Jun 7 14:55:39 2012 PE route changed
       Jun 7 14:55:39 2012 Out lbl Update                     16015
       Jun 7 14:55:39 2012 In lbl Update                     262210
       Jun 7 14:55:39 2012 loc intf down
Eric Guo Mon, 06/30/2014 - 11:10
hello
has  your problem been resolved already ? since I am starting work on same setup right now. could you mind share your Cisco end configuration to me without your confidential information?
thanks, please let me know if possible.
Eric
Related Content
