CUCM, VCS and Codian MCU
Jun 8th, 2012
I have integrated a VCS and a CUCM and I am able to make calls between them. Now I am planning to add an MCU to this setup but I am not sure which solution is best. Should I register the MCU to VCS or CUCM or both?
Tufan
Tomonori Taniguchi Fri, 06/08/2012 - 00:59
  • Cisco Employee,
Probably there is no “best” answer on this question.
However this will be depend on how many Endpoint/SIP UA under VCS and CUCM and whether or not using call escalation feature on CUCM.
If you are planning to use MCU more with Endpoint/SIP UA under VCS also planning to use VCS-E in future expansion for inbound/outbound traversal call, probably make more sense MCU to register on VCS for now.
Also if you are planning to use Multiway feature, MCU should register on VCS (and BFCP which still have few limitation while call handle by CUCM).
