Warning message
QoS on Cisco ASA 5505 configured as Easy VPN Client
Jun 8th, 2012
I have Cisco ASA 5505 configured as easy vpn client (mode network extension). Asa connects to internet by DSL link with 10Mbps/1Mbps bandwidth.
I have configured split-tunneling on ASA 5510 which is acting as a VPN concentrator so that people at remote office could go out and browse the web. I want to set QoS so that VPN traffic gets a bigger portion of bandwidth (upload and download) and limit NON-VPN trafic to some predefined value (again both upload and download) with speceific accent on upload as it is only 1Mbps. I have created class-map named vpn-traffic and used access-lists to match ESP and ISAKMP packets. Since asa is configured as easy vpn client I can't use tunnel-group as match criteria, or I could but i dont know how?
The idea was to match VPN traffic to class vpn-traffic and let all other traffic fall to class-default class and then apply policies to those classes. Below is the configuration of my ASA5505. There is a problem with configuration as all traffic is limited to value configured for class-default class. Command "show service-policy police" shows that VPN traffic is classified to both classes. How can I fix this?
ASA Version 8.4(1)
hostname ciscoasa
domain-name default.domain.invalid
enable password ------------------- encrypted
passwd ------------------- encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.13.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa841-k8.bin
ftp mode passive
dns server-group DefaultDNS
object network obj_any
subnet 0.0.0.0 0.0.0.0
access-list VPNQOS extended permit udp any any eq isakmp
access-list VPNQOS extended permit esp any any
access-list VPNQOS extended permit udp any any eq 4500
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-641.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.13.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh 192.168.13.0 255.255.255.0 inside
ssh timeout 30
console timeout 0
vpnclient server xxx.xxx.xxx.xxx
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup GROUP1 password *****
vpnclient username USER1 password *****
vpnclient enable
dhcpd auto_config outside
dhcpd address 192.168.13.2-192.168.13.33 inside
dhcpd dns 192.168.1.5 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username admin password ------------------ encrypted privilege 15
class-map vpn-traffic
match access-list VPNQOS
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
policy-map qos-out
class vpn-traffic
  police input 9000000 10500
  police output 768000 10500
class class-default
  police input 1000000 1000
  police output 256000 1000
service-policy global_policy global
service-policy qos-out interface outside
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:9fe208a62d936b8402043d5ba089c1a0
: end
ciscoasa#
