QoS policing command
Jun 8th, 2012
I have read the conception of single-rate,two-color policing, single-rate three-color policing and two-rate three-color policing. But I don’t know how to implement them with policing command. Policing commands are so complicated and make me so confused with them
police bps ] [pir bps [be burstbytes]] [conform-action action [exceed-action action [violate-action action]]]
police cir bps ] [pir bps [be burst-bytes]] [conform-action action [exceed-action action [violate-action action]]]
what do bps, normal-burst-bytes, maximum-burst-bytes and burst-bytes mean? When should I use keyword cir,bc ,be and pir? Could you give me some examples with commands?
Thanks a lot
Martin
David Santos Fri, 06/08/2012 - 16:20
Can this table help you?
CB Policing Mechanics
Feature
Behavior of    Single-Rate, Two-Color
Behavior of    Single-Rate, Three-Color
Behavior of    Dual-Rate, Three-Color
Size of   "first" bucket
Bc (bytes)
Bc (bytes)
Bc (bytes)
Size of   "second" bucket
N/A
Be (bytes)
Be (bytes)
Refill of first bucket
Prorated portion of Bc based on packet arrival time
Refill of second   bucket
N/A
Filled by spilled Tokens from refill of first bucket
Prorated portion of Be based on packet arrival time
Logic for   "conform" action
1st bucket => packet size; decrement 1st bucket by packet size
1st bucket => packet size; decrement   both buckets by packet size
Logic to choose "exceed" action
All packets that do not conform
Doesn't conform, but 2nd bucket =>   packet size; decrement 2nd bucket by packet size
Logic to choose "violate" action
N/A
All other packets
All other packets
