When to upgrade to a new firewall
Jun 8th, 2012
When do you know it is time to upgrade to a new firewall?  From the Cisco Podcast #7 "Monitoring Firewall Performance", the speakers said when the CPU usage consistently is at 50% or higher, that is the time to upgrade.  They gave their reasons which made sense.  And I can check the CPU usage with a show cpu usage command.
Are there any other signs beside CPU usage that it is time to upgrade the firewall?
Thanks.
J
Marcin Latosiewicz Fri, 06/08/2012 - 12:28
  • Cisco Employee,
J,
I assume you mean hardware not software upgrade.
If you are not running any additional features (like threat detection, inspections, various proxies) and are reaching 50% you might consider an upgrade indeed, especially if you're seeing spiky load.
However before making a decision like this, I would run this by TAC. Don't get me wrong, TAC does not perform capacity planning, but will at least tell you about features that consume CPU, which you might not be using/needing.
M.
Marvin Rhoads Sat, 06/09/2012 - 15:54
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
A couple of reasons should prompt an hardware or plafform upgrade:
1. When your performance demands exceed the capacity of your current system
2. When you want to avail yourself of services that your current device does not support
3. When your current device has exceeded its support lifetime (typically five years after end of sales for Cisco products).
Hope this helps
nkarthikeyan Sun, 06/10/2012 - 03:04
  • Gold, 750 points or more
1) Yes. If your device is reaching 50 % of the cpu usage then you may need to upgrade for the consistent performance.
but the cpu usage increase may be due to other issues as well. But if everything is normal and cpu usage is crossing 50% then you may need to upgrade. This is one of the reason only. there are lot other.
2) Depends on your future expansion / requirement you may need for an upgrade in the model.
Feature
Cisco ASA 5505
Cisco ASA 5510
Cisco ASA 5520
Cisco ASA 5540
Cisco ASA 5550
product_data_sheet0900aecd802930c5-01
product_data_sheet0900aecd802930c5-02
product_data_sheet0900aecd802930c5-03
product_data_sheet0900aecd802930c5-04
product_data_sheet0900aecd802930c5-05
Users/Nodes
10, 50, or unlimited
Unlimited
Unlimited
Unlimited
Unlimited
Firewall Throughput
Up to 150 Mbps
Up to 300 Mbps
Up to 450 Mbps
Up to 650 Mbps
Up to 1.2 Gbps
Maximum Firewall and IPS Throughput
• Up to 150 Mbps with AIP-SSC-5
• Up to 150 Mbps with AIP-SSM-10
• Up to 300 Mbps with AIP-SSM-20
• Up to 225 Mbps with AIP-SSM-10
• Up to 375 Mbps with AIP-SSM-20
• Up to 450 Mbps with AIP-SSM-40
• Up to 500 Mbps with AIP-SSM-20
• Up to 650 Mbps with AIP-SSM-40
Not available
3DES/AES VPN Throughput***
Up to 100 Mbps
Up to 170 Mbps
Up to 225 Mbps
Up to 325 Mbps
Up to 425 Mbps
IPsec VPN Peers
10; 251
250
750
5000
5000
Premium AnyConnect VPN Peers* (Included/Maximum)
2/25
2/250
2/750
2/2500
2/5000
Concurrent Connections
10,000; 25,000*
50,000; 130,000*
280,000
400,000
650,000
New Connections/Second
4000
9000
12,000
25,000
33,000
Integrated Network Ports
8-port Fast Ethernet switch (including 2 PoE ports)
5 Fast Ethernet ports; 2 Gigabit Ethernet + 3 Fast Ethernet ports*
4 Gigabit Ethernet, 1 Fast Ethernet
8 Gigabit Ethernet, 4 SFP Fiber, 1 Fast Ethernet
Virtual Interfaces (VLANs)
3 (no trunking support)/20 (with trunking support)*
50/100*
150
200
400
Security Contexts (Included/Maximum)*
0/0
0/0 (Base); 2/5 (Security Plus)
2/20
2/50
2/50
High Availability
Not supported; stateless Active/Standby and redundant ISP support*
Not supported; Active/Active and Active/Standby**
Expansion Slot
1, SSC
1, SSM
1, SSM
1, SSM
User-Accessible Flash Slot
USB 2.0 Ports
3 (1 on front, 2 on rear)
Serial Ports
1 RJ-45 console
2 RJ-45, console and auxiliary
Rack-Mountable
Yes, with rack-mount kit (available in the future)
Yes
Yes
Yes
Yes
Wall-Mountable
Yes, with wall-mount kit (available in the future)
Not available
Not available
Not available
Not available
Security Lock Slot (for Physical Security)
Yes
Not available
Not available
Not available
Not available
Technical Specifications
Memory
512 MB
1 GB
2 GB
2 GB
4 GB
Minimum System Flash
128 MB
256 MB
256 MB
256 MB
256 MB
System Bus
Multibus architecture
the above table shows the maximum capability of the ASA firewalls. when the requirement needs upgrade you have to go for that.
3) When it comes for end of support from Cisco tech.
these are the major factors for an upgrade.
do rating if the info is helpful.
cheers
Karthik
