7010 part number
Jun 8th, 2012
CTI-7010-TPSRV-K9
LIC-7010-TPSINTOP
LIC-7000-TPSRV16
CTI-7010-TPSRV-K9
LIC-7010-TPSINTOP
Are enough to have CTS endpoints in meeting with 9 screens?
Does the LIC-7000-TPSRV16 is just to upgrade from 9 to 16.
What about CTS endpoints with TIP/DTLS without
LIC-7010-TPSINTOP
Saurabh Gupta Sat, 06/09/2012 - 11:53
Hi Pascal,
I would advise you to please get in touch with your Cisco Account Manager or Pre-Sales person to obtain righ information.
//Saurabh
Paul Anholt Sat, 06/09/2012 - 12:42
Justin,
You would not need LIC-7010-TPSINTOP as this is for 3rd party endpoints only, not CTS endpoints. For encryption you would also need a seperate license: LIC-AESCDN7-K9
Paul
Tomonori Taniguchi Sat, 06/09/2012 - 23:14
You may select LIC-7000-TPSRV9 or LIC-7000-TPSRV16 as default screen port license in initial order.
If you are looking conference with up to 9 screens in total, then LIC-7000-TPSRV9 will works fine.
You may purchase additional screen port license later on as additional screen to expand your bridge capability.
LIC-7010-TPSINTOP is to support connection with 3rd party Endpoint/MCU.
CTS Endpoint has native convertibility with TPS Series Bridge. Therefore this option is necessary if your environment has only CTS Endpoint.
LIC-AESCDN6-K9 is enabling AES encryption call as well as HTTPS for Web GUI for TPS management and operation.
Other option which not part of your initial list is LIC-AESCDN6-K9.
Please note that due to export license control, the encryption key may not install when TPS ship out from Cisco and need to install it separately once you receive it.
