CUIC - Control Center - Device is showing Unkown
Jun 10th, 2012
I installed CUIC 8.5.3 in VMWare and none of the reports are showing any data.  All of the data sources are showing online, but when I look in the Control Center the CUIC device is showing as Unknown and I am not able to Shutdown/Start/Reset it.  The options are grayed out.  Is this normal behavior?
Ryan
david.macias Sun, 06/10/2012 - 09:06
  • Blue, 1500 points or more
No, it's not.  Do you have DNS, can you ping yourself from the cli?  I've never installed CUIC on a VM, so don't know for sure if it will work, but can't see that it wouldn't.
david
Ryan Gunn Sun, 06/10/2012 - 11:32
Yeah pings all work fine.  I have also verified that CUIC is supported in VMWare.  We are going to open a High Sev Cisco Suport case to see if they are able to tell what is going on
Related Content
