Warning message
SGE2010P Voice and data vlan
Jun 10th, 2012
I'm new for SMB switches and very defficult to configure voice vlan and data
here my setup
I have 5 x cisco SGE2010P 48 POE switches and working as standlone.
SW1 (Port 21-22) Trunk / LAG1-------> SW2 (Port 24-48) Trunk / LAG 1
SW1 (Port 23-24) Trunk / LAG 2-------> SW3 (Port 24-48) Trunk / LAG 1
SW1 (Port 45-46) Trunk / LAG 3 -------> SW4 (Port 24-48) Trunk / LAG 1
SW1 (Port 47-48) Trunk / LAG 4-------> SW5 (Port 24-48) Trunk / LAG 1
Vlan 1 Default and Vlan 2 voice
how can i member voice vlan and data vlan for access ports in all 5 witches because
thanks
Danushka
Overall Rating: 3 (1 ratings)
Davidwagman1 Wed, 06/13/2012 - 19:32
  • Gold, 750 points or more
Hi Danushka,
Are you asking how to assign vlans to ports?
I've attached the manual below, take a look at p. 42 on how to create vlans and hen the following pages on how to assign them to the ports. Please let me know if this answers your question.
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2024p/administrati...
Best regards,
David
Please rate helpful posts.
Danushka Kaluar... Wed, 06/13/2012 - 22:18
Hi David,
Thanks for your reply. it is ok adding vlan in the port. i was asking about voice and data vlan.
if we need to add voice vlan and data vlan for access port in SMB switches, how we can implement those two vlan for access ports.
according to our setup. please advice how we can implement voice and data. if any things wrong in my setup kindly advise.
SGE2010P dose no have option to add voice vlan.
Thanks in advance.
Danushka
Davidwagman1 Thu, 06/14/2012 - 03:51
Danushka,
What firmware are you using? It is one of the Linksys branded models or the newer cisco branded models?
Best regards,
David
Danushka Kaluar... Thu, 06/14/2012 - 04:15
Thanks for reply David,
This is New Cisco brand SGE2010P.
Switch Details
1)" type="hidden" value=""/>
Model Name48-port 10/100/1000 Ethernet Switch with PoE
System Name
System Location
System Contact
System Object ID1.3.6.1.4.1.9.6.1.73.2010.3
System Up Time3 days , 21 hours , 3 minutes , 20 seconds
Base MAC Addressd4:d7:48:be:3c:1a
Hardware  Version00.00.01
Software  Version3.0.0.18
Boot  Version2.0.0.03
Switch Operation Mode After  Reset Standalone     Stack
Jumbo Frame Enable            Disable
please advise.
Thanks Danushka
Davidwagman1 Thu, 06/14/2012 - 05:40
Hi Danushka,
Ok, sorry about sending you the wrong manual before.
I found the following video that may be helpful, I think its what you're looking to do:
https://ciscosales.webex.com/ciscosales/ldr.php?AT=pb&SP=MC&rID=59265352&rKey=9aa0dc12383802fb
Its from this thread:  https://supportforums.cisco.com/thread/2136733
Also, just to provide you the proper manual:
http://www.cisco.com/en/US/docs/switches/lan/csbms/sfe2000/administration/guide/SFE-SGE2xxx_Admin_Guide.pdf
Let me know if that video helped.
Best,
David
Danushka Kaluar... Thu, 06/14/2012 - 06:11
Thanks David for your support.
think is in that video we have to enable all ports trunks instead of access.
that case we have to enableall ports for trunks in 5 switches.
why this diffrent from catalyst. do you think this is good idea enabling all port on trunk mode.
please advice.
because i stuck now and giving issue with my IP telephone system.
Danushka
Davidwagman1 Thu, 06/14/2012 - 06:22
Hi Danushka,
Access mode will only allow for one untagged vlan on the port, so that won't work for your application where you're looking to have 2 vlans on the port - one for voice, one for data. So you must use trunk mode. In reading your post, I am assuming that you are needing both vlans on each port, correct? For example, the phone plugs directly into the switch, and the PC plugs into the switch port on the phone, and each are on separate vlans?
A quicker way to make the necessary changes, in my opinion, is via CLI. You can adapt the sample commands below to your needs. This will set port 3 as a trunk port, allowing traffic on Native vlan (1 - untagged) and vlan 2 (tagged):
interface gigabitethernet3
switchport trunk allowed vlan add 2
Best,
David
Davidwagman1 Fri, 06/15/2012 - 09:59
Hi Danushka,
Any luck with the config?
Best regards,
David
Danushka Kaluar... Sun, 06/17/2012 - 22:58
Sorry for delay reply.
I tried with trunk mode at the moment and want keep few days to monitor whether it is ok or not.
another things is in you video i saw that voice go as a tagged and data go as a untagged. but IP PHONE system go with untagged.
I was trying to do so but i could not able to communicate with IP phone system. when enable trunk in that port i could able to communicate with pohne system.
i do not know why.
I used Avaya IP office 500 and Avaya phones.
if any kindly advice.
also kindly let me know how can i use below command in these switches. i could not find out how to use this command in cli.
Danushka
Davidwagman1 Mon, 06/18/2012 - 08:33
Hi Danushka,
As I am not familiar at all with the operation of Avaya phones and systems, I can't be too much help beyond configuring the switch with the proper vlans. Sorry. Just to confirm, the phones are working properly? What isn't working as you expected?
I think the CLI you're looking for is:
switchxxxxxx# config t
switchxxxxxx(config)# interface gigabitethernet3
switchxxxxxx(config-if)# switchport mode trunk             !-  if not already in trunk mode
switchxxxxxx(config-if)# switchport trunk allowed vlan add 2
What error are you getting with that command?
Danushka, if you could please rate any helpful posts using the stars, or if any solved your initial question, please mark it as correct answer, it would be appreciated.
Best,
David
Danushka Kaluar... Mon, 06/18/2012 - 21:46
we can not use above command as we do in cisco catalyst.
but still i am facing issue with my phone system.
yes SBS POE switches are not good as we expected.
Davidwagman1 Tue, 06/19/2012 - 06:42
Hi Danushka,
Thats odd.. Those commands work for me in my SBS switch, though it is a SG300 model.
I am still not sure what the problem is with your phones, and what you're trying to achieve. Please be as specific as possible for me, or anyone, to help you further. Please also consider contacting SBS support.
Best regards,
David
Danushka Kaluar... Wed, 06/20/2012 - 22:04
Hi David,
i have mentioned before that i am using cisco SMB SGE2010P switches.
when we telnet we got only this window. how we can configure in this what you mentioned before.
please advice.
I need to configure access prot in data and voice
voice vlan 2
data vlan 3
regards,
Danushka
bhackbarth Fri, 06/22/2012 - 11:30
The SGE2010P doesn't have CLI, so there's no way you will be able to enter those commands. However if you access the web interface and click on VLAN Managment, interface settings, you should be able to set a port as trunk mode. Then under port VLAN membership you can then assign the VLANs...one untagged VLAN (data, native VLAN) and a tagged VLAN (voice).  The menu labels might not be exactly correct but I think those are the ones to look under.
Tom Watts Fri, 06/29/2012 - 17:57
  • Green, 3000 points or more
Hello Danushka, the SGE2010P switches only support the GUI and the menu driven console. Any other access to the switch is unsupported.
Can you please provide the follow information?
Is the voice gateway and data gateway the same or separate?
Does your router support vlan tags?
For the VLAN configuration, it depends what is your goal. Depending on your topology, the uplink configuration will vary as well.
If you plan to use only a telephone on the port, this should be an untagged member of the voice vlan ID.
If you plan to use a telephone + computer on the same switchport, the data vlan is untagged while the voice vlan is tagged.
Please keep in mind the SGE2010P switch does not have any advanced voice features such as CDP or auto voice vlan. This means you will have to manually configure your telephones operation vlan ID as your voice vlan and enable any PCtoPort vlan.
If you would like assistance you may call the SBSC support center 24/7 at 1.866.606.1866. Please have prepared your CCOID, serial number and supply this community forum post.
AdamBatey Tue, 07/24/2012 - 20:15
This is really very poor on Cisco's part.  The data sheet for thsi switch states:
The Cisco SFE2010 is optimized for maximum system availability, with fully redundant stacking, and dual images for resilient firmware upgrades. The switch helps secure the network through IEEE 802.1Q VLANs, IEEE 802.1X port authentication, access control lists (ACLs), denial-of-service (DoS) prevention, and MAC-based filtering. The enhanced quality of service (QoS) and traffic-management features help ensure clear and reliable voice and video communications.
This is very misleading; when you read about the switches ability to provide QoS for voice and the switch sits higher up the tech tree than switches that support phones people would tend to support something as common as cdp for cisco phones!
Whats the point of QoS for voice if you can't hook up the cisco phones!  and I mean with a PC as well.
very disapointing!
