06-11-2012 02:41 AM - edited 03-19-2019 05:04 AM
Hello
Can you help me in determining the number of CVP Licenses installed on my company .
Noha
06-11-2012 01:31 PM
You can look on the diagnostics page of CVP
http://
However I believe they are always licensed for 1000 ports. You are trusted to not use more ports than you have purchased.
Graham
06-11-2012 01:50 PM
Dear Graham
From diagnostics page I can found that I have total 1200 port , However I am sure that I purchased 120 port only .
i need to confirm the number of purchased licenses .
Noha
06-11-2012 02:05 PM
The current CVP server can run a maximum of 1200 SIP sessions so Cisco give you a license for 1200 ports. If you purchased 120 port licenses then you are trusted to only use 120 ports.
You cannot find out how many ports you purchased from the license file. You will have to ask your accounts.
Graham
06-11-2012 02:19 PM
ok
can i know the utilization of these ports ( real time or historical ) to know if i reached the maximum or not.
