how to test cisco 1252G-E-K9 access point 802.11/N capability
Jun 11th, 2012
Hi friends,
could anyone tell me how to test Cisco 1252G-E-K9 wireless access point's 802.11/N capability. we have bunch of these models configured on 802.11/g and connected to WLC. Thanks
Scott Fella Tue, 06/12/2012 - 02:02
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Well the most you can get out of the 2.4ghz will be 144mbps. You either need to use open authentication or wpa2/aes for 802.11n. Also on the SSID, you need to make sure WMM is enabled. To test, simply connect an 802.11n compatible device to the SSID and look at your connection. Anything over 54mbps connection, you are using 802.11n. Some devices will show you 'N', but some will just show connection speed.
Faisal Shabbir Tue, 06/12/2012 - 04:33
Thanks Scott for your reply as i mentioned that we have already deployed 1252G APs currently they are configured to support 802.11g/a and we want to move them to N. now i want to configure one of the AP to test the speed and compatibility with laptops and phone devices. Thanks
Scott Fella Tue, 06/12/2012 - 19:11
  • Hall of Fame,
    2017 Wireless
Okay, the ap model you posted is just a 2.4ghz. 1252AG-E-k9 is dual band. So the question is, do you have it configured correctly or not? To test you you need an 802.11n device and you need to try to connect to the 5ghz (300 Mbps) max or the 2.5ghz (144 Mbps) max.
Leo Laohoo Tue, 06/12/2012 - 20:14
  • Hall of Fame,
    2017 LAN, Wireless
Configure 802.11n on the WLC
Troubleshoot 802.11n Speeds
Not all devices can support 802.11n.  Smartphones (such as Android or all Apple iPhones) and tablets (Android and all Apple iPads and iTouch) cannot and will not support 802.11n speed.  Read the article below.
Designing 'iPad WLANs' poses new, renewed challenges
Faisal Shabbir Tue, 07/10/2012 - 21:11
there is requirement from higher management to enable 802.11N along with 802.11b/g. I enabled 802.11N on one WISM and connected my laptop with but I am getting variable and its even less than 54mbps speed. although, my wireless connections shows that its  802.11n connection. please help!!!
Surendra BG Tue, 07/10/2012 - 21:14
  • Cisco Employee,
wats the auth and the encryption set on the AP or on the WLC??
Surendra BG Tue, 07/10/2012 - 21:21
  • Cisco Employee,
WMM enabled?? and all MCS rates enabled?
Surendra BG Tue, 07/10/2012 - 21:25
  • Cisco Employee,
802.11N is enabled with all MCS rates enabled??
Surendra BG Tue, 07/10/2012 - 21:27
  • Cisco Employee,
Wats the client driver and the version??
Surendra BG Tue, 07/10/2012 - 21:30
  • Cisco Employee,
Connect the  client and then on the WLC search for that client and provide the screenshot..
WLC monitor >> Clients >> Client MAC >> Click on it >> Screenshot
Surendra
Surendra BG Tue, 07/10/2012 - 21:36
  • Cisco Employee,
sh client detail
On the WLC when you are facing the issue
Surendra BG Tue, 07/10/2012 - 21:38
  • Cisco Employee,
please click on that MAC address and you will see even more details regarding the client.. and paste the screenshot
Surendra BG Tue, 07/10/2012 - 21:46
  • Cisco Employee,
may be we need this from the CLI..
show client details
Surendra BG Tue, 07/10/2012 - 21:58
  • Cisco Employee,
Strange!!
This should show the datarate at which you are connected to!! am not able see that!!
Surendra
Faisal Shabbir Tue, 07/10/2012 - 22:03
tell me any other command from where you can get your required details. above output i copy paste from CLI
Surendra BG Tue, 07/10/2012 - 22:04
  • Cisco Employee,
i see this on my WLC
(WLC1) >show client detail 00:40:96:b4:59:70
Client MAC Address............................... X>XXXXXXXXX
Client Username ................................. lab
AP MAC Address................................... XXXXXXXXXXXX
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 5
BSSID............................................XXXXXXXXXX
Connected For ................................... 86 secs
Channel.......................................... 44
IP Address....................................... 9.8.88.101
Association Id................................... 1
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... 5
Client E2E version............................... No E2E support
Diagnostics Capability........................... Supported
S69 Capability................................... Supported
Re-Authentication Timeout........................ 1743
QoS Level........................................ Silver
802.1P Priority Tag.............................. disabled
WMM Support...................................... Enabled
--More-- or (q)uit
Power Save....................................... OFF
Current Rate..................................... 54.0
Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0,
    ............................................. 48.0,54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ No
Policy Manager State............................. XXXXXXXX
Policy Manager Rule Created...................... Yes
AAA Override ACL Name............................ wlc-acl
AAA Override ACL Applied Status.................. Yes
  • Cisco Employee,
Current rate points to 54 in mine.. am not able t osee that on urs!!
wats the WLC software code?
Faisal Shabbir Tue, 07/10/2012 - 22:10
Product Version.................................. 5.0.148.2
RTOS Version..................................... Linux-2.6.10_mvl401
Bootloader Version............................... 4.1.171.0
Surendra BG Tue, 07/10/2012 - 22:10
  • Cisco Employee,
Really sorry to say.. the software is end of support and its End of Engineering as well. any way we can upgrade and see??
Faisal Shabbir Tue, 07/10/2012 - 22:13
now which version i required ??? and how to upgrade the IOS i never done it before. and from where to get IOS version
Faisal Shabbir Tue, 07/10/2012 - 22:28
surendra could you tell from where i can find exact model info of wism ???
Faisal Shabbir Tue, 07/10/2012 - 22:48
another query after upgrading the IOS of WISM do i need to upgrade the APs as well ???
Leo Laohoo Wed, 07/11/2012 - 21:36
  • Hall of Fame,
    2017 LAN, Wireless
The WiSM will upgrade the WAP firmware.
Leo Laohoo Fri, 07/13/2012 - 22:11
  • Hall of Fame,
    2017 LAN, Wireless
Surendra's being diplomatic.  Firmware 5.X is very, very buggy.
If you can run 5.X firmware then even money's on you having WiSM-1.  Otherwise, on CLI you can see what you've got when you enter the command "sh sysinfo".
Trending Topics - Security & Network
