Query Related to HSRP
Answered Question
I want to know that after enabling the HSRP , whether both the routers(active & standby) are using virtual IP for routing the packets or can it use one of the its  assigned IP.
Correct Answer by Peter Paluch about 4 years 10 months ago
Hello Nitin,
I agree with Smitesh. Your Linux should be using only one default gateway - the vIP address 10.32.23.49.
Please note that there are two incorrect aspects of your current configuration:
  1. There is no such thing as a separate default gateway for a particular interface. The Linux has a common routing table, and defining a "default gateway" results in a normal default route 0.0.0.0/0 being added to the routing table with the IP address of the next hop set to the address of the "default gateway". If you define four different default gateways, you will either end up with the routing table having a single default route 0.0.0.0/0 through four different next hops, or the routing table will contain the default route through only a single next hop (either the first or the last one - that depends on many factors). Once more, regardlessly of how many network cards you have, you should use only one default gateway - in this case, the vIP address of the entire HSRP standby group.
  2. Your current configuration of "per-interface default gateways" is furthermore incorrect because the address of the default gateway lies outside your directly connected networks. Your four NICs belong to the IP network 10.32.23.48/28 while the defined default gateways are somewhere in the 10.31.X.X range, clearly outside your directly connected network 10.32.23.48/28. A default gateway must always be located on a directly connected network, otherwise it is invalid and not accepted. I suppose that is also the reason why the route output you have posted does not contain any default route at all.
Best regards,
Peter
Correct Answer by smitesh kharecha about 4 years 10 months ago
Hi Nitin,
Configure your Eth 1, 2, 3 ,4 & 5 to have Gateway IP of 10.32.23.49 and I guess then everything should work as a charm...
HTH,
Smitesh
PS: Please rate helpful posts...
Correct Answer by Sandeep Choudhary about 4 years 10 months ago
HI Nitin,
I am agree with Peter.
Using HSRP, a set of routers work in concert to present the illusion of a single virtual router to the hosts on the LAN.  This set is known as an HSRP group or a standby group.A single router elected  from the group is responsible for forwarding the packets that hosts send to the virtual router.This router is known as the active router.Another router is elected as the standby router.  In the event that the active router fails, the standby assumes the packet forwarding duties of the active router.  Although an arbitrary number of routers may run HSRP, only the active router forwards the packets sent to the virtual router.
   To minimize network traffic, only the active and the standby routers send periodic HSRP messages once the protocol has completed the election process.  If the active router fails, the standby router takes over as the active router.  If the standby router fails or becomes the active router, another router is elected as the standby router.
They usually use the real ip address of the router to communicate via default gateway( HSRP hello packets).
Plz rate if it helps.
Correct Answer by Kishore Chennupati about 4 years 10 months ago
Welcome  back my friend. So glad to see u again
Hello Nitin,
Any router in a standby group is fully reachable under its real IP address and this IP address remains functional regardless of the HSRP. In other words, you can always use these real IP address to contact the routers or to perform routing via these IP addresses as default gateways.
In addition, the Active router also uses the virtual IP address and can be contacted using that IP address.
Does this answer your question?
Best regards,
Peter
Overall Rating: 5 (5 ratings)
Correct Answer
Peter Paluch Tue, 06/12/2012 - 04:07
  • Cisco Employee,
Hello Nitin,
Best regards,
Peter
Correct Answer
Kishore Chennupati Tue, 06/12/2012 - 04:15
  • Gold, 750 points or more
Peter Paluch Tue, 06/12/2012 - 15:09
  • Cisco Employee,
Hello Kishore,
Thank you buddy! It's still difficult for me to get back to CSC as often as I would like to but I hope to see things improve a bit in the next couple of days.
Best regards,
Peter
Correct Answer
Sandeep Choudhary Tue, 06/12/2012 - 04:27
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
HI Nitin,
thanks for reply ...
Below are the some analysis (through wireshark) on each linux  interface. It seem that each interface is communicating with only one  particular IP address .
Before HSRP Disable:
eth2 (10.32.23.55)
10.32.23.55 ---- ARP request(unicast) ---->> 10.31.22.197 (Degault gateway)
10.32.23.55 <<---- ARP reply(unicast) ----   10.31.22.197 (Degault gateway)
eth3 (10.32.23.54)
10.32.23.54 ---- ARP request(unicast) ---->> 10.31.11.70 (router)
10.32.23.54 <<---- ARP reply(unicast) ----   10.31.11.70 (router)
eth4 (10.32.23.53)
10.32.23.53 ---- ARP request(unicast) ---->> 10.31.13.76 (router)
10.32.23.53 <<---- ARP reply(unicast) ----   10.31.13.76 (router)
eth5 (10.32.23.53)
10.32.23.52 ---- ARP request(unicast) ---->> 10.31.24.72 (router)
10.32.23.52 <<---- ARP reply(unicast) ----   10.31.24.72 (router)
After HSRP Enable:
eth2 (10.32.23.55)
  (ARP request sent by Standby router )
10.32.23.52 (eth5) <<---- ARP request(Broadcast) ----  10.32.23.50 (Standby router) virtual IP Address: 10.32.23.49
10.32.23.55 (eth2) <<---- ARP request(Broadcast) ----  10.32.23.50 (Standby router) virtual IP Address: 10.32.23.49
Can you please suggest is it correct behavior ?
Can standby router send ARP request using its real IP ?
Peter Paluch Tue, 06/12/2012 - 15:21
  • Cisco Employee,
Hello Nitin,
I am having trouble understanding the different IP addresses displayed in your post. Would you please answer the following questions?
  1. What is the virtual IP address of the HSRP group?
  2. What are the individual real IP addresses of the routers in the HSRP group?
  3. What are the IP addresses and netmasks of the individual Ethernet interfaces at the Linux box?
  4. What is the default gateway configured on the Linux box? Would it be possible to show the output of the ip route command?
Thank you!
Best regards,
Peter
Thanks for reply ..........
Below are the IP details :
1. virtual IP address of the HSRP group is 10.32.23.49.
2. Individual IP addresses of the routers is 10.32.23.51 (active) & 10.32.23.50 (standby).
3. IP addresses of the individual Ethernet interfaces at the Linux box are:
ifconfig
eth0      Link encap:Ethernet  HWaddr 00:25:B3:1C:B9:7E
          inet addr:192.231.36.82  Bcast:192.231.36.255  Mask:255.255.255.0
          inet6 addr: fe80::225:b3ff:fe1c:b97e/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
eth1      Link encap:Ethernet  HWaddr 00:25:B3:1C:B9:7C
          inet addr:10.32.23.56  Bcast:10.32.23.63  Mask:255.255.255.240
          inet6 addr: fe80::225:b3ff:fe1c:b97c/64 Scope:Link
eth2      Link encap:Ethernet  HWaddr 00:1F:29:5A:B5:E9
          inet addr:10.32.23.55  Bcast:10.32.23.63  Mask:255.255.255.240
          inet6 addr: fe80::21f:29ff:fe5a:b5e9/64 Scope:Link
eth3      Link encap:Ethernet  HWaddr 00:1F:29:5A:B5:E8
          inet addr:10.32.23.54  Bcast:10.32.23.63  Mask:255.255.255.240
          inet6 addr: fe80::21f:29ff:fe5a:b5e8/64 Scope:Link
eth4      Link encap:Ethernet  HWaddr 00:1F:29:5A:B5:EB
          inet addr:10.32.23.53  Bcast:10.32.23.63  Mask:255.255.255.240
          inet6 addr: fe80::21f:29ff:fe5a:b5eb/64 Scope:Link
eth5      Link encap:Ethernet  HWaddr 00:1F:29:5A:B5:EA
          inet addr:10.32.23.52  Bcast:10.32.23.63  Mask:255.255.255.240
          inet6 addr: fe80::21f:29ff:fe5a:b5ea/64 Scope:Link
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
4.
O100282:~# route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
10.31.11.70     *               255.255.255.255 UH    0      0        0 eth3
10.31.24.72     *               255.255.255.255 UH    0      0        0 eth5
10.31.22.197    *               255.255.255.255 UH    0      0        0 eth2
10.31.13.76     *               255.255.255.255 UH    0      0        0 eth4
10.32.23.48     *               255.255.255.240 U     0      0        0 eth2
10.32.23.48     *               255.255.255.240 U     0      0        0 eth3
10.32.23.48     *               255.255.255.240 U     0      0        0 eth4
10.32.23.48     *               255.255.255.240 U     0      0        0 eth5
10.32.23.48     *               255.255.255.240 U     0      0        0 eth1
10.117.18.128   10.32.23.49     255.255.255.192 UG    0      0        0 eth1
10.17.5.128     10.32.23.49     255.255.255.128 UG    0      0        0 eth1
192.231.36.0    *               255.255.255.0   U     0      0        0 eth0
O100282:~# arp
Address                  HWtype  HWaddress           Flags Mask            Iface
localhost                        (incomplete)                              eth0
10.31.24.72              ether   00:19:E8:77:86:08   C                     eth5
10.31.11.70              ether   00:19:E8:77:86:08   C                     eth3
10.32.23.49              ether   00:19:E8:77:86:08   C                     eth2
192.231.36.1             ether   00:1E:0B:F9:C3:B2   C                     eth0
10.32.23.49              ether   00:19:E8:77:86:08   C                     eth1
O100281                  ether   00:23:7D:26:CA:66   C                     eth0
10.31.13.76              ether   00:19:E8:77:86:08   C                     eth4
10.31.22.197             ether   00:19:E8:77:86:08   C                     eth2
Correct Answer
smitesh kharecha Wed, 06/13/2012 - 03:21
  • Silver, 250 points or more
Hi Nitin,
HTH,
Smitesh
Thanks for reply smitesh..
But each interface is configured with different gateway .
eth2 (10.32.23.55) -------->> 10.31.22.197 (Degault gateway)
eth3 (10.32.23.54) ---->> 10.31.11.70 (Degault gateway)
eth4 (10.32.23.53) ---->> 10.31.13.76 (Degault gateway)
eth5 (10.32.23.53) ---->> 10.31.24.72 (Degault gateway)
smitesh kharecha Wed, 06/13/2012 - 05:15
You need atleast one port to have gateway as VIP IP ( in your case 10.32.23.49)...
HTH,
Smitesh
Correct Answer
Peter Paluch Wed, 06/13/2012 - 12:51
  • Cisco Employee,
Hello Nitin,
Best regards,
Peter
Hi Peter,
I added default gateway, but still i am facing same problem & below are the outputs:
Command: ip addr show
1: lo: mtu 16436 qdisc noqueue state UNKNOWN
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
       valid_lft forever preferred_lft forever
2: sit0: mtu 1480 qdisc noop state DOWN
    link/sit 0.0.0.0 brd 0.0.0.0
3: eth0: mtu 1500 qdisc pfifo_fast state UP qlen 1000
    link/ether 00:25:b3:1c:b9:7e brd ff:ff:ff:ff:ff:ff
    inet 192.231.36.82/24 brd 192.231.36.255 scope global eth0
    inet6 fe80::225:b3ff:fe1c:b97e/64 scope link
4: eth2: mtu 1500 qdisc pfifo_fast state UP qlen 100
    link/ether 00:1f:29:5a:b5:e9 brd ff:ff:ff:ff:ff:ff
    inet 10.32.23.55/28 brd 10.32.23.63 scope global eth2
    inet6 fe80::21f:29ff:fe5a:b5e9/64 scope link
5: eth3: mtu 1500 qdisc pfifo_fast state UP qlen 100
    link/ether 00:1f:29:5a:b5:e8 brd ff:ff:ff:ff:ff:ff
    inet 10.32.23.54/28 brd 10.32.23.63 scope global eth3
    inet6 fe80::21f:29ff:fe5a:b5e8/64 scope link
6: eth4: mtu 1500 qdisc pfifo_fast state UP qlen 100
    link/ether 00:1f:29:5a:b5:eb brd ff:ff:ff:ff:ff:ff
    inet 10.32.23.53/28 brd 10.32.23.63 scope global eth4
    inet6 fe80::21f:29ff:fe5a:b5eb/64 scope link
7: eth5: mtu 1500 qdisc pfifo_fast state UP qlen 100
    link/ether 00:1f:29:5a:b5:ea brd ff:ff:ff:ff:ff:ff
    inet 10.32.23.52/28 brd 10.32.23.63 scope global eth5
    inet6 fe80::21f:29ff:fe5a:b5ea/64 scope link
8: eth1: mtu 1500 qdisc noop state DOWN qlen 1000
    link/ether 00:25:b3:1c:b9:7c brd ff:ff:ff:ff:ff:ff
9: bond0: mtu 1500 qdisc noop state DOWN
    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
10: bond1: mtu 1500 qdisc noop state DOWN
Command: ip route show table all
10.31.11.70 dev eth3  scope host
10.31.24.72 dev eth5  scope host
10.31.22.197 dev eth2  scope host
10.31.13.76 dev eth4  scope host
10.32.23.48/28 dev eth5  proto kernel  scope link  src 10.32.23.52
10.32.23.48/28 dev eth2  proto kernel  scope link  src 10.32.23.55
10.32.23.48/28 dev eth3  proto kernel  scope link  src 10.32.23.54
10.32.23.48/28 dev eth4  proto kernel  scope link  src 10.32.23.53
192.231.36.0/24 dev eth0  proto kernel  scope link  src 192.231.36.82
default via 10.32.23.49 dev eth5
default via 10.32.23.49 dev eth2
default via 10.32.23.49 dev eth3
default via 10.32.23.49 dev eth4
broadcast 127.255.255.255 dev lo  table local  proto kernel  scope link  src 127.0.0.1
broadcast 192.231.36.255 dev eth0  table local  proto kernel  scope link  src 192.231.36.82
broadcast 10.32.23.63 dev eth5  table local  proto kernel  scope link  src 10.32.23.52
broadcast 10.32.23.63 dev eth2  table local  proto kernel  scope link  src 10.32.23.55
broadcast 10.32.23.63 dev eth3  table local  proto kernel  scope link  src 10.32.23.54
broadcast 10.32.23.63 dev eth4  table local  proto kernel  scope link  src 10.32.23.53
broadcast 192.231.36.0 dev eth0  table local  proto kernel  scope link  src 192.231.36.82
local 192.231.36.82 dev eth0  table local  proto kernel  scope host  src 192.231.36.82
broadcast 10.32.23.48 dev eth5  table local  proto kernel  scope link  src 10.32.23.52
broadcast 10.32.23.48 dev eth2  table local  proto kernel  scope link  src 10.32.23.55
broadcast 10.32.23.48 dev eth3  table local  proto kernel  scope link  src 10.32.23.54
broadcast 10.32.23.48 dev eth4  table local  proto kernel  scope link  src 10.32.23.53
local 10.32.23.55 dev eth2  table local  proto kernel  scope host  src 10.32.23.55
local 10.32.23.54 dev eth3  table local  proto kernel  scope host  src 10.32.23.54
local 10.32.23.53 dev eth4  table local  proto kernel  scope host  src 10.32.23.53
broadcast 127.0.0.0 dev lo  table local  proto kernel  scope link  src 127.0.0.1
local 10.32.23.52 dev eth5  table local  proto kernel  scope host  src 10.32.23.52
local 127.0.0.1 dev lo  table local  proto kernel  scope host  src 127.0.0.1
local 127.0.0.0/8 dev lo  table local  proto kernel  scope host  src 127.0.0.1
local ::1 via :: dev lo  proto none  metric 0  mtu 16436 advmss 16376 hoplimit 4294967295
local fe80::21f:29ff:fe5a:b5e8 via :: dev lo  proto none  metric 0  mtu 16436 advmss 16376 hoplimit 4294967295
local fe80::21f:29ff:fe5a:b5e9 via :: dev lo  proto none  metric 0  mtu 16436 advmss 16376 hoplimit 4294967295
local fe80::21f:29ff:fe5a:b5ea via :: dev lo  proto none  metric 0  mtu 16436 advmss 16376 hoplimit 4294967295
local fe80::21f:29ff:fe5a:b5eb via :: dev lo  proto none  metric 0  mtu 16436 advmss 16376 hoplimit 4294967295
local fe80::225:b3ff:fe1c:b97e via :: dev lo  proto none  metric 0  mtu 16436 advmss 16376 hoplimit 4294967295
fe80::/64 dev eth0  metric 256  expires 8531085sec mtu 1500 advmss 1440 hoplimit 4294967295
fe80::/64 dev eth5  metric 256  expires 8531106sec mtu 1500 advmss 1440 hoplimit 4294967295
fe80::/64 dev eth2  metric 256  expires 8531106sec mtu 1500 advmss 1440 hoplimit 4294967295
fe80::/64 dev eth4  metric 256  expires 8531106sec mtu 1500 advmss 1440 hoplimit 4294967295
fe80::/64 dev eth3  metric 256  expires 8531106sec mtu 1500 advmss 1440 hoplimit 4294967295
ff00::/8 dev eth0  metric 256  expires 8531085sec mtu 1500 advmss 1440 hoplimit 4294967295
ff00::/8 dev eth5  metric 256  expires 8531106sec mtu 1500 advmss 1440 hoplimit 4294967295
ff00::/8 dev eth2  metric 256  expires 8531106sec mtu 1500 advmss 1440 hoplimit 4294967295
ff00::/8 dev eth4  metric 256  expires 8531106sec mtu 1500 advmss 1440 hoplimit 4294967295
ff00::/8 dev eth3  metric 256  expires 8531106sec mtu 1500 advmss 1440 hoplimit 4294967295
