HWIC not showing after upgrading IOS
Answered Question
Jun 12th, 2012
HI,
I have Cisco 2801 router with IP Base image, i have upgraded its image into advance Ip services for using IP SLA features but after upgradation HWIC card not showing in configuration.
When i recall IP base image then configuration show presence of HWIC card but with advance IP services HWIC card not showing.
Kindly advice.
BR,
Arshad Ahmed
Correct Answer by Leo Laohoo about 5 years 1 week ago
Right-o.  You need a minimum of 12.4(20)T (IP Base feature set) to get to work.
1- and 2-Port Fast Ethernet High-Speed WIC for Cisco Integrated Services Routers
What is the HWIC card (exact part number)?
What is the exact IOS (post the "sh version" if you're not sure)?
Overall Rating: 5 (2 ratings)
Jeff Van Houten Tue, 06/12/2012 - 18:48
  • Silver, 250 points or more
You need to research the hardware supported for the specific version of ios and the specific hardware you are using.
Talha Ansari Tue, 06/12/2012 - 21:47
Hi Arshad,
Hope you have not downgraded the IOS version in the process of upgrading the featureset. Post here the current and previous image names.
Talha
Correct Answer
Leo Laohoo Tue, 06/12/2012 - 21:59
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Arshad Khan Tue, 06/12/2012 - 22:50
Dear All,
Kindly note down the IOS, ROUTER and HWIC details.
Router PID: CISCO2801 VO5
Previous IOS : c2801-ipbase-mz.124-15.T10
Current IOS :  c2801-advipservicesk9-mz.124-25a.bin
HWIC : HWIC-1FE
Arshad Ahmed
Correct Answer
Leo Laohoo Tue, 06/12/2012 - 23:01
  • Hall of Fame,
    2017 LAN, Wireless
Richard Burts Wed, 06/13/2012 - 10:49
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Arshad Ahmed
Clearly you have conflicting requirements. The features that you want require a version of code that requires physical resources greater than what your router has. There are only a couple of alternatives and you may not like any of the alternatives:
- you can upgrade RAM and flash.
- you can choose which of the features you can get along without (have the IP SLA without the WIC or have the WIC without the IP SLA).
Rick
Arshad Khan Wed, 06/13/2012 - 22:02
Dear all,
Thanks for your helpfull reply.
I have order for DRAM and FLASH in this regards.
Arshad Ahmed
