Internet through VPN problem.
Jun 12th, 2012
Hello. I have a problem configuring a vp n client to work with internet through the vpn. I have made the following config (to couple it with a ZBF config) and when i connect with the vpn client i can only browse https websites (port 443). Port 80 seems to work, it NAT's but i always get a pae cannot be displayed. Any help will be great. Thanks a lot,
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key XXXXX address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 10
crypto isakmp client configuration group cisco
key XXXXX
dns 172.16.10.1
pool VPN-Pool
netmask 255.255.255.248
crypto isakmp profile VTI
   match identity group cisco
   isakmp authorization list default
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile vti
set transform-set ESP-3DES-SHA
set isakmp-profile VTI
interface Virtual-Template1 type tunnel
ip unnumbered Loopback0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
tunnel source Dialer0
tunnel mode ipsec ipv4
tunnel protection ipsec profile vti
Related Content
