A9K SPAN
Jun 12th, 2012
Two DNS Server connected to two ASR9K,g0/0/0/1 and g0/0/0/2,
Q: I want to monitor DNS Server traffic in and out. and Port spanning  four ethernet port of two DNS Server to one destination port.
      Can I use a switch connected two ASR9K. and I monitor asr9k,g0/0/0/1 and g0/0/0/2 to destination g0/0/0/3.100 at each Asr9k.
      now the monitor traffic carry through the switch to the sniffer? or can you give me your advise,thx.
here is the config
asr9k_R1:
monitor-session DNS
destination interface g0/0/0/3.100
interface g0/0/0/1 l2transport
monitor-session DNS
interface g0/0/0/2 l2transport
monitor-session DNS
interface g0/0/0/3.100 l2transport
encapsulation dot1q 100
rewrite ingress tag pop 1
asr9k_R2:
monitor-session DNS
monitor-session DNS
monitor-session DNS
switch:
int f0/24
des connected to sniffer_server
sw mo acc sw acc vlan 100
int f0/1
des connected to asr9k_r1
sw mode trunk
sw trun en dot1q
int f0/2
des connected to asr9k_r2
sw mode trunk
sw trunk en dot1q
Overall Rating: 5 (2 ratings)
Chenjiannan Tue, 06/12/2012 - 08:02
another question:Does the switch need to config the port span ?
Alexei Kiritchenko Mon, 06/18/2012 - 00:11
  • Cisco Employee,
Hello Jiannan,
Yes, you can have a switch for R-SPAN and you configuration with a vlan tag rewrite is correct.
I don’t think we need a span session on that switch. ASR9k mirror all traffic pushing vlan tag 100 and sending it out of g0/0/0/3.100.
The switch would flood it back to the 2nd ASR9k (the traffic would be dropped there assuming g0/0/0/3.100 is not participating in any L2VPN) and flood it to the sniffer popping VLAN tag 100.
/A
