ASA 5505 License and Smartnet selection
mckenziemgmt
We purchased an ASA 5505 (ASA5505-BUN-K9) and more recently purchased the license to upgrade it from 10 to 50 users (L-ASA5505-10-50).
I would like to provide remote access to users via AnyConnect - specifically, AnyConnnect on Windows plus the iPhone/iPad and Android versions.  My understanding is that I should purchase the Anyconnect Essentials (L-ASA-AC-E-5505) and Anyconnect Mobile (L-ASA-AC-M-5505) licenses.  Is this correct?  If I do this, how many simultaneous remote access VPN connections (via Anyconnect clients) will the ASA then support?
Further, we did not initially purchase Smartnet with this device, but I would like to do so to gain access to software updates.  Is there a site or document where I can locate the SKU #'s for Smartnet contracts that would be appropriate with our device?  Or could someone provide a few example SKU #'s?
The output of "show version" is below:
Cisco Adaptive Security Appliance Software Version 8.3(1)
Device Manager Version 6.3(1)
Compiled on Thu 04-Mar-10 16:56 by builders
System image file is "disk0:/asa831-k8.bin"
Config file at boot was "startup-config"
asa1 up 42 secs
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.06
0: Int: Internal-Data0/0    : address is 649e.f3b3.c2bb, irq 11
1: Ext: Ethernet0/0         : address is 649e.f3b3.c2b3, irq 255
2: Ext: Ethernet0/1         : address is 649e.f3b3.c2b4, irq 255
3: Ext: Ethernet0/2         : address is 649e.f3b3.c2b5, irq 255
4: Ext: Ethernet0/3         : address is 649e.f3b3.c2b6, irq 255
5: Ext: Ethernet0/4         : address is 649e.f3b3.c2b7, irq 255
6: Ext: Ethernet0/5         : address is 649e.f3b3.c2b8, irq 255
7: Ext: Ethernet0/6         : address is 649e.f3b3.c2b9, irq 255
8: Ext: Ethernet0/7         : address is 649e.f3b3.c2ba, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : 8              perpetual
VLANs                          : 3              DMZ Restricted
Dual ISPs                      : Disabled       perpetual
VLAN Trunk Ports               : 0              perpetual
Inside Hosts                   : 50             perpetual
Failover                       : Disabled       perpetual
VPN-DES                        : Enabled        perpetual
VPN-3DES-AES                   : Enabled        perpetual
SSL VPN Peers                  : 2              perpetual
Total VPN Peers                : 10             perpetual
Shared License                 : Disabled       perpetual
AnyConnect for Mobile          : Disabled       perpetual
AnyConnect for Cisco VPN Phone : Disabled       perpetual
AnyConnect Essentials          : Disabled       perpetual
Advanced Endpoint Assessment   : Disabled       perpetual
UC Phone Proxy Sessions        : 2              perpetual
Total UC Proxy Sessions        : 2              perpetual
Botnet Traffic Filter          : Disabled       perpetual
Intercompany Media Engine      : Disabled       perpetual
This platform has a Base license.
Thanks!
Jennifer Halim
Yes you are correct, you would need to purchase AnyConnect Essential license as well as AnyConnect Mobile, and you could run 25 maximum concurrent AnyConnect sessions
Here is the supported Android devices for your reference:
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect25/release/notes/rn-ac2.5-android.html#wp1159723
For Smartnet, depending on which service level you require, here are some examples for ASA5505:
- SMARTnet Premium 24x7x4 (SNTP): CON-SNTP-AS5B50K9
- SMARTnet 8x5xNBD (SNT): CON-SNT-AS5B50K9
Jennifer Halim
Thanks!
