Warning message
Need advice of QoS config before implementation
Jun 12th, 2012
Hi team,
I am going to be implementing some QoS across the network of the company I work for. I am no expert in it but have come up with the following, but would love it if some more experienced professionals could look over it before I implement it.
What am I trying to achieve? Simple, we have a 20mbps link and I want 50% to always be used for our SAN traffic that is being backed up to another site and then after hours and weekends, this goes up to 70% and 80% respectively.
We have video conferencing so I want that to always go first. The LAN is setup and the switches are tagging DSCP values to the video and SAN traffic.
With the Policy map SHAPE_TRAFFIC, I am not sure which one to use. Thanks in advance.
class-map match-aLL VIDEO_QoS
match  dscp cs5
class-map match-aLL SAN_REPLICATION
match  dscp cs1
policy-map QoS_POLICY
class VIDEO_QoS
  priority percent 10
class SAN_REPLICATION
  priority percent 50
policy-map SAN_AFTERHOURS
  priority percent 70
  ip access-list SAN_AFTERHOURS
policy-map SAN_WEEKENDS
  priority percent 80
  ip access-list SAN_WEEKENDS
Class class-default
  shape average 20000000
  service policy QoS_POLICY
  service policy SAN_AFTERHOURS
  service policy SAN_WEEKENDS
OR
Class SHAPE_TRAFFIC
  Shape average 2000000
Class class-default
Fair-queue
ip access-list extended SAN_AFTERHOURS
permit ip any any time-range SAN_REPLICATION_WEEKDAYS
ip access-list extended SAN_WEEKENDS
permit ip any any time-range SAN_REPLICATION_WEEKENDS
periodic weekdays 17:30 to 23:59
periodic weekdays 00:00 to 07:00
periodic weekend 00:00 to 23:59
Overall Rating: 4 (1 ratings)
David Salazar Wed, 06/13/2012 - 07:07
1) By default on the Cisco routers you can setup the 75% of the interface bandwidth, the 25% is reserved for control traffic. For this when you are configure the policy map you can not exceed on all classes (exclude default-class) 75%.
2) the priority queue is only one, if you mixed diference type of traffic (example: video and SAN) on separate class-map but both using the priority queue is not a good idea.
3) What type os traffic is your SAN traffic, who much rate of bandwidth consume it? Is UDP or TFP traffic?
4) how are you controlling the traffic rate now for the lin of 20Mbps?
5) one more thing, why you are using time-range for the same traffic? Its important point here is modify the bandwidth assign to the class reference to the date. Maybe you can schedule a cron job or use EEM.
Cory Dryden Wed, 06/13/2012 - 15:03
1) Thanks for that. Previously the max-reserved bandwidth command is implemented and has 90 after it.
2) I did read after posting this what you are referring to.
3) The guy who runs it says TCP
4) There is not any shaping on the router at present. Theinterface is 100mbps full duplex.
5) Time range was so that after hours or weekends, the SAN traffic uses more of the link.
Joseph W. Doherty Wed, 06/13/2012 - 10:11
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You shouldn't be able to define multiple service-polices within the same class.  Also when you shape, most shapers don't account for L2 overhead, so you then need to shape 5 to 15% slower to allow for it.
Although your time based ACLs could be used to effectively match different classes, the problem is it doesn't deactivate the class and the class percentages are always active and you can't exceed total available.  However non-LLQ classes are relative so you could get something close to what you desire if you work ratios. 50% is 1:1, 70% is 7:3 and 80% is 4:1.  So, something like:
time-range SAN_REPLICATION_AFTERHOURS
permit ip any any time-range SAN_REPLICATION_AFTERHOURS
match  dscp cs5
match  dscp cs1
class-map match-all SAN_AFTERHOURS
match access-group SAN_AFTERHOURS
match class-map SAN_REPLICATION
class-map match-all SAN_WEEKENDS
match access-group SAN_WEEKENDS
class VIDEO_QoS
  priority percent 10
class SAN_WEEKENDS
  bandwidth percent 12
class SAN_AFTERHOURS
  bandwidth percent 7
  bandwidth percent 3
class class-default
  bandwidth percent 3
Policy map SHAPE_TRAFFIC_20Mbps
Class class-default
  shape average 18000000
NB: QoS features vary by platform and IOS, so the above might need editing.
Cory Dryden Wed, 06/13/2012 - 15:05
Thanks Joseph for taking the time to write that up. I understand what you are saying except for why you use the ratios you were talking about.
If anyone can point me to some doco on QoS that would be awesome. Right from the start would be great!
Joseph W. Doherty Wed, 06/13/2012 - 15:42
Disclaimer
Posting
I used ratios to provide your requested 50%, 70% and 80% allocations for SAN traffic.
You noted, during weekdays, you wanted to provide SAN 50% of the bandwidth but 70% weeknights and 80% weekends.  You did this by using 3 different policies, but you cannot have all 3 active.  You need the desired policy at the desired time.  You could probably set up some complex scheduling to change configs on the fly, but what I did was define a single policy that will deliver the same results.  I did this by using ratios between classes to correspond to your desired percentages.
For example, on weekends when you want 80% for SAN, that leaves 20% for other non-SAN traffic.  The ratios between 80% to 20% is 4:1.  In the policy map I defined, I set bandwidths to 12% and 3%, for SAN traffic during weekends, which is also 4:1, so you obtain your desired 80% to 20%.  For non-LLQ classes the percentages used aren't caps, they just set a relative scheduling weights.
Cory Dryden Thu, 06/14/2012 - 15:27
Ok I understand that. Why 12 and 3 though? Why not any other numbers that make up a 4:1 ratio or am I looking into that too much?
Joseph W. Doherty Thu, 06/14/2012 - 17:46
Disclaimer
Posting
Least common denominator with the other two ratios.
80:20=4:1=12:3
70:30=7:3
50:50=1:1=3:3
Related Content
