06-13-2012 07:30 AM - edited 03-07-2019 07:13 AM
Greetings, what command clears these counters on a WS-3750-48P switch? I looked at the clear counters ? output and none of the options appears to fit?
3750#show plat port-asic stats drop fa1/0/9
Interface Fa1/0/9 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 150107
Weight 1 Frames 9
Weight 2 Frames 253
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 102224
Queue 3
Weight 0 Frames 22112
Weight 1 Frames 0
Weight 2 Frames 42406
Thanks in advance for your time and attention!
Solved! Go to Solution.
06-13-2012 05:58 PM
These are the port-asic counters and cannot be cleared from the CLI. The only way they're reset is on reload.
Dale
06-13-2012 07:47 AM
have you tried: clear mls qos int fa1/0/9 statistic
plz Rate if it helped.
Soroush
06-13-2012 07:53 AM
Yes, tried that command, did not clear the drop stats. Thanks though!
06-13-2012 05:06 PM
What about if you just do "clear counters"?
RG-
06-13-2012 05:58 PM
Dale
