Warning message
CUCM - Trace
Jun 13th, 2012
Hi All ,
I read through the CCM SDI logs. Just want to know some info on CCM traces on acadamic purposes.
Below lines are from sdi traces of SIP trunk call.
23:30:57.392 |DET-MediaExchange-(95)::fillAudioMediaInfo, partyIdx=0, xferMode=16, codec=15, maxFramesPerPacket=30i, sRTP=0, mediaSecurity=1|1,100,56,1.942973^^SEP001EF7C2AD14
23:30:57.392 |DET-MediaExchange-(95)::fillAudioMediaInfo, partyIdx=1, xferMode=4, codec=15, maxFramesPerPacket=20i, sRTP=0, mediaSecurity=1|1,100,56,1.942973^^SEP001EF7C2AD14
xferMode - What is mean ?
3:30:57.367 |SIG-MediaManager-(69)::wait_AuConnectRequest, CI(32286197,32286198), capCount(6,8), mcNodeId(0,0), xferMode(16,4), reConnectType(0), mrid (0, 0) IFCreated(0 0) proIns(0 0), AC(0,0) party1DTMF(3 2 101 1 0) party2DTMF(1 3 0 0 0),reConnFlag=0, connType(3,3), IFHand(0,0),MTP(0,0),MRGL(,32952426-29c5-555e-50ef-56bd743e2fb0) videoCap(0 0), mmCallType(0),FS(0,0) IpAddrMode(0 0) aPid(1, 74, 701), bPid(1, 57, 38) EOType(2 0) MohAnnConnType(0 0)|1,100,56,1.942972^10.228.193.166^SEP001EF7C2AD14
3 2 101 1 0 -- What is meaning of these values ? . 101 - DTMF Payload .
Thanks in Advance ...
Overall Rating: 5 (1 ratings)
Joseph Martini Wed, 06/13/2012 - 17:05
  • Cisco Employee,
I don't know what xferMode means since I've never used it's value for any trace reading or problem solving that I can remember.  The party1DTMF mode values indicate, prefer2833 which is the DTMF preference, then 2833 indicating support for 2833 only, followed by the 2833 payload type, followed by 1 which means True that the endpoint wants DTMF reception.
Abhay Reyal Thu, 09/03/2015 - 07:39
  • Silver, 250 points or more
Xfer Mode 16 :- must be for the SIP.
Xfer Mode basically tells method of telling other CCM subsystems what types of
devices the RTP audio connection is between.
For Example :- 3 is for H323_MODE , 4 for Agena , 7 for H323
I hope this helps
Abhay Singh Reyal
avinsrid89 Thu, 09/03/2015 - 10:31
I cannot remember these values from the top of my head. But these values can be given to you in detail if you ask a TAC engineer.
xFermode refers to the phone protocol type. If I recollect right, 4 is Agena (SCCP Phone).
Party1DTMF( 3 2 101 1 0) --> crucial values are black, red, green
BLACK: The preferred dtmf method --> 3 --> RFC2833 + OOB
RED: The supported DTMF method --> 2 --> RFC2833
GREEN: The DTMF RTP Payload in case we support in band DTMF. --> 101 -->RFC 2833 Payload 101
party2DTMF: 1 --> OOB .. 3 --> RFC2833+OOB, 0 --> No in band DTMF specific payload
The preferred DTMF method generally takes values from the Preferred DTMF check box in SIP Trunk --> i.e. No Preference, RFC2833 (101 payload), RFC2833 + OOB
Please rate useful posts!
~Avinash
