Warning message
FWSM shows snmp string & tacacs key in clear text
Jun 13th, 2012
FWSM module loaded with IOS version 4.0(12) shows snmp string & tacacs key in clear text in show running config. Is there any solution to make it encrypted in show run.
Ramraj Sivagnan... Sat, 07/28/2012 - 19:54
  • Silver, 250 points or more
Hi Bro
This cannot be done, not even in the latest Cisco FWSM 4.1.8 image. "Maybe" there's a hidden Cisco command to achieve this, which I'm not aware off.
P/S: If you think this comment is useful, please do rate them nicely :-)
nkarthikeyan Sat, 07/28/2012 - 22:37
  • Gold, 750 points or more
Hi Samarjit,
Please do check to have service password-encryption enabled in your device.
As far as i know for snmp you are not giving any key.... you give only the string which will not get encrypted. If you have enabled the service password-encryption in your device. Then your tacacs key will get encrypted to level 7 encrption automatically. Else it will take 0 by default with plain text. But this also even it will not do md5 encryption for those password.
Please do rate if the given information helps.
By
Karthik
bzyczek77 Tue, 12/03/2013 - 06:01
That does not work on Firewalls ASA or FWSM
I am also running currently with 4.1(8) version ... Can anyone tell me if the later versions resolve this issue?
