Warning message
Incident WLC2012 syslog
Jun 13th, 2012
Good afternoon,
Within the Wireless Lan Controller of the Company I have configured the syslog level "Informational" and the level of syslog facility "syslog".
In Msg Log Configuration is in Buffered Log Level "Emergencies" and Console Log Level "Errors". All this is set to the MANAGEMENT tab, however the syslog messages it receives that is pointing to are the following, We required to send messages to the syslog server for users connecting to wireless networks and authentication , any idea what is wrong configured?
Jun 13 17:08:12 10.213.116.20 WLC: *aaaQueueReader: Jun 13 18:08:10.864: %AAA-4-RADSERVER_NOT_FOUND: radius_db.c:2057 Could not find appropriate RADIUS server for WLAN 4 - no authentication servers configured
Jun 13 17:08:15 10.213.116.20 WLC: *apfProbeThread: Jun 13 18:08:13.750: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:7138 Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored.
Jun 13 17:08:19 10.213.116.20 WLC: *osapiReaper: Jun 13 18:08:18.545: %OSAPI-6-FILE_DOES_NOT_EXIST: osapi_file.c:348 File : /proc/122/stat does not exist.(errno 2)
Jun 13 17:08:19 10.213.116.20 WLC: -Traceback: 084bfc89 084c7b63 084ca010 084cc2fa 084c6ced 08d8b5aa 08dd217a
Amjad Abdullah Fri, 06/15/2012 - 05:11
  • Red, 2250 points or more
good day harold,AFAIK auth info ca not be sent to syslog server. it does not appear on msflog in the wlc.
however, it appears on traplog.
you can find auth information on the traplog. you need to configure an external snmp trap receiver to receive the logs.
by the way, your logs above indicate that one of your wlans does not have the radius server configured. (from gui that is available under wlan config -> security tab.)
Amjad
dramanueva123 Wed, 04/09/2014 - 11:33
estoy teniendo problemas para activar el log exacto al cual necesito,quiero que me muestre la mac el timestamp y el id , y por ahora los log que active no me estan tirando esa informacion
que facility level y que severity level deberia setear , por favor es importante si puede ayudarme
PD la autenticacion es solo por mac osea q las mac registradas permiten lo demas no
harold.morales Tue, 04/08/2014 - 13:02
No lo resolvimos por medio de syslog, creo que lo hicimos por medio de la configuración de un  SNMP receiver
Trending Topics - Security & Network
