Warning message
3750v2-24FS IOS compatibility
Answered Question
Jun 13th, 2012
Snippet below is from:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_bulletin_c25-639468.html
Question:  Will IOS c3750-ipbasek9-mz.122-55.SE4.bin boot/load and function correctly on a 3750v2-24FS?
Based on the snippet below, I suspect not.
When I booted up the device, I saw in the startup/boot process that the IOS checked to see if the bootldr had to be upgraded (did not need to be upgraded).  Device shipped with c3750-ipbasek0-mz.122-55.EY.bin
Thank you.
PB639468
Overview
Cisco is announcing Cisco IOS® Software for the new Cisco® Catalyst® 3750V2-24FS Switch with IP Base software. The Cisco Catalyst  3750V2-24FS Switch is a fixed-configuration enterprise Ethernet switch  with 24 100FX Small Form-Factor Pluggable (SFP) Ethernet downlink  connectivity and 2 Gigabit Ethernet uplink ports. The Cisco Catalyst  3750V2-24FS Switch is part of the Cisco Catalyst 3750 v2 series of  stackable switches offering StackWise® technology and advanced LAN services.
Table 1 shows the Cisco Catalyst 3750V2-24FS Switch specifications.
Table 1. Cisco Catalyst 3750V2-24FS Switch Specifications
Product Name
Part Number
Description
Cisco Catalyst 3750V2-24FS-S
WS-C3750V2-24FS-S
Cisco Catalyst 3750V2 24 100BASE-FX SFP ports + 2 Gigabit Ethernet SFP, IP Base image
This  product bulletin provides content and delivery information for Cisco  IOS Software Release 12.2(55)EY, which is the first Cisco IOS Software  release that provides support for the Cisco Catalyst 3750V2-24FS Switch.  Cisco IOS Software Release 12.2(55)EY is an early deployment release  based on Cisco IOS Software Release 12.2(55)SE. Cisco IOS Software  Release 12.2(55)EY should not be used for any switch other than the  Cisco Catalyst 3750V2-24FS Switch.
The  platform and features delivered with Cisco IOS Software Release  12.2(55)EY will be incorporated into Cisco IOS Software Release  12.2(58)SE and subsequent Cisco IOS Software 12.2SE releases. Note that  there are no planned maintenance releases for this release. Also note  the migration path to the latest Cisco IOS Software 12.2SE release  (Figure 1). Customers should prepare to upgrade using this migration  path.
Correct Answer by Leo Laohoo about 5 years 2 months ago
Oh nuts.  I did NOT see the "FS"!
You'll need to run a minimum of 12.2(55)SE5 to be able to get the FS to work.
My sincerest apologies.
Recovering Catalyst Fixed Configuration Switches from a Corrupted or Missing Image
Overall Rating: 5 (1 ratings)
Leo Laohoo Wed, 06/13/2012 - 16:29
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
12.2(55)SE4 will work on a 3750v2.
KnowledgeAcquirer Wed, 06/13/2012 - 22:53
Switch
Description
Supported by Minimum Cisco IOS Release
WS-3750V2-24FS
24 SFP module slots and 2 SFP module slots
Cisco IOS Release 12.2(55)SE5
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/release/notes/OL23054.html#wp1042020
With c3750-ipbasek9-mz.122-55.SE4.bin, WS-3750V2-24FS generates a hardware and firmware incompatible message; device endlessly tries to reboot.
Once 12.2(55)SE5.bin or the preloaded EY.bin is restored, WS-3750V2-24FS boots correctly.
KnowledgeAcquirer Thu, 06/14/2012 - 15:10
Proof that  SE4.bin will not work on WS-3750v2-24FS
Loading "flash:c3750-ipbasek9-mz.122-55.SE4.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c3750-ipbasek9-mz.122-55.SE4.bin" uncompressed and installed, entry
point: 0x1000000
executing...
Error: hardware not supported by firmware.
       Try loading newer software instead.
       System Resetting...
Loading "flash:c3750-ipservicesk9-mz.122-55.SE4.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c3750-ipservicesk9-mz.122-55.SE4.bin" uncompressed and installed, en
try point: 0x1000000
executing...
       System Resetting...
Correct Answer
Leo Laohoo Thu, 06/14/2012 - 15:16
  • Hall of Fame,
    2017 LAN, Wireless
KnowledgeAcquirer Thu, 06/14/2012 - 15:23
Not a problem.  First FS I've had an opportunity to work with and shipped with the latest IOS EY.bin
Leo Laohoo Thu, 06/14/2012 - 21:17
  • Hall of Fame,
    2017 LAN, Wireless
"EY" IOS????
Wow!  I've never seen that before!
Thanks for the ratings.
KnowledgeAcquirer Mon, 06/18/2012 - 06:19
This is a 3750v2-24FS, that is, with the optional SFP modules.
I get an error message stating “Firmware is incompatible with IOS”.
I get the flash_init to load at the ROMMON prompt but not the load_helper.
Thank you.
