Cisco ASA5505 - DMZ Connection
Jun 13th, 2012
My first time programming a Cisco ASA - Have to get my feet wet sometime right?
Anyways I''m trying to setup up Ethernet 0/6 to be a DMZ Connection
When I add port 0/6 to DMZ it gives me an error saying "The IP Address X.X.X.X /Subnet Mask cannot overlap the subnet of interface outside"
So my question is I have an outside connection already configured - How can I make a DMZ connection with the same subnet mask with a different IP?
Mitchell Dyer Wed, 06/13/2012 - 19:24
Hello Kevin,
You will need to setup the DMZ interface in a different subnet using an address range from RFC1918 (192.168.0.0-192.168.255.255, 172.16.0.0-172.172.31.255.255, 10.0.0.0-10.255.255.255) and then NAT traffic from the 'dmz' to the 'outside'. You will also need to modify the access-lists accordingly.
Please post your config and I'd be happy to get you pointed in the right direction, also -- please indicate whether you are using a base or security plus license and what software version you are running (both items can be found by issuing "show version").
-Mitch
