How Migrating ASA 5520 to ASA 5550
Answered Question
Jun 14th, 2012
Dear Support
I have ASA 5520 using ios 8.2(2)
I received a new ASA 5550 and want to transfert my config from 5520 to 5550,
How can i do this?
Correct Answer by blimmer2007 about 1 year 10 months ago
I think this should be fairly straightforward (may be shot down in flames here!!).
Install same versions of ASA and ASDM software on new ASA (5550).
Backup config of 5520
Load backed up config on to new 5550
Test
As long as the versions are the same I believe the configs should run on either system.  You will obviously have to setup the new one "offline" (not plugged into your live environment) as you will get IP conflicts and cause yourself all sorts of issues!!
I stand to be corrected on all of the above as I have never done this myself but, in theory, I think it should work fine.
Tim
Average Rating: 5 (1 ratings)
Correct Answer
blimmer2007 Thu, 06/14/2012 - 04:01
Test
Tim
IPNET-SERVICES Thu, 06/14/2012 - 05:14
Hi Tim
I did like you said, its work fine in lab environement
So, i need to connect my new ASA 5550 to my network and test applications
Thanks a lot
Login or Register to take actions
Posted June 14, 2012 at 2:45 AM
Stats:
Replies:2 Avg. Rating:5
Views:354 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 7,866
2 6,140
3 3,170
4 1,473
5 1,446
