Warning message
CME incoming Call should display name instead number
Jun 14th, 2012
i have CME 8.6 and have configured a local directory with external numbers. But if i dial from a number which is in the local directory from outside i only see the number and not the configured name in the Local directory?
What did i wrong?
Jason
Overall Rating: 4 (2 ratings)
Kenneth Mohammed Thu, 06/14/2012 - 20:13
  • Silver, 250 points or more
Try putting this command under telephony-service
config t
telephony-service
service dnis directory-lookup
Hope that helped, if so please rate
born.jason Fri, 06/15/2012 - 10:02
Hmm sounds good but don`t help me... :-/
i have an entry for an external caller
directory entry 13 067434165129 name External Caller
i have added the two commands under telephony-service
service dnis overlay
service dnis dir-lookup
But if the caller from external comes in i can only see the number and not the name. :-(
Any idea?
Cristian Iconaru Mon, 11/11/2013 - 01:29
as kenneth said, this should work:
telephony-service
directory entry 1 00123456789 name NAME
Carlo Poggiarelli Mon, 11/11/2013 - 02:44
  • Green, 3000 points or more
Hi Jason.
To achieve this, Paolo Bevilacqua wrote a script, number2name that you can find at http://www.ciscoscripts.com
Very useful
Carlo
Please rate all helpful posts
"The more you help the more you learn"
