Dial peer question
Jun 14th, 2012
We have a voice-gateway connected to a PBX ( for local access) , and to a SBC-Session Border Controller ( for PSTN access), from its configuration here you have a pair of dial-peers:
dial-peer voice 12 pots
huntstop
destination-pattern 130567734..
incoming called-number .T
direct-inward-dial
port 1/0:D          <---- to PBX
forward-digits 4
dial-peer voice 26 voip
huntstop
destination-pattern 1305.......
voice-class codec 1
session protocol sipv2     <---- to SBC
session target ipv4:172.20.11.10
session transport udp
tech-prefix 1
dtmf-interworking rtp-nte
num-exp 305 1305
If this router receives a call from PSTN to 3056773422 while link to PBX is down (port 1/0:D).....
Is it possible that router matches with dial-peer voice 26 and return call toward SBC connection???
Or router should generate a reorder tone (after matching with dial-peer 12)???
Thanks for your help
Enrique Villasana
Chris Deren Fri, 06/15/2012 - 06:29
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You will need to remove "huntstop" on dial peer 12 for that to work, if you remove it then it will route to it as it also matches the same pattern (less explicit makes it secondary).
Chris
ev1205 Mon, 07/09/2012 - 14:47
Hi Chris Deren.
I was working on another project and forgot this old problem, but I am back.
As you said, If I do not remove "huntstop" on dial peer 12, the call never will be routed via dial-peer 26???.
Thanks for your very importat help...
Enrique Villasana
