Voice gateway for branch.
Answered Question
Jun 14th, 2012
I have cme in the main site. I need a cheap voice gateway (router) with 4 fxo ports for the branch.. Which model can I use?.
The wan connection is dedicated 1024kbps.
Thanks.
Overall Rating: 5 (1 ratings)
Chris Deren Thu, 06/14/2012 - 18:04
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Any of the 29XX ISR G2 will do just fine. 2901 for example would be a cheap candidate.
Chris
Rafael Jimenez Fri, 06/15/2012 - 09:28
The ip phones in the branch must register with cme at the branch. the fxo are for local calls.
the 2900 is an expensive solution.
I would like to know, if a router 800 with a voice gw image will work?.
Correct Answer
Chris Deren Fri, 06/15/2012 - 10:08
  • Hall of Fame,
