06-14-2012 08:35 PM
Hi friends,
Just a small quick Q to confirm this approach is correct or not?
I have a HO where I will be putting in WAAS CM (WAVE 274) and a WAAS appliance (WAVE 694). The plan is to run the interception in "inline mode".
Now the branch office (BO) is having WAAS SM on a ISR 2900 router. And I was advised that this site would be running the interception in "WCCP" mode.
While i was a reading about configuring WCCP it mentioned that all the devices in the WAAS network across the WAN must be running WCCP including the routers edge routers on both ends.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v441/quick/guide/waasqcg.html#wp1416970
So my question was, in my network environment do I need to have both WAE devices intercepting in WCCP mode or i could use both, inline at HO and WCCP at BO?
Mohit
Solved! Go to Solution.
06-15-2012 06:13 AM
Hi Mohit,
It's perfectly fine to run different interception mechanisms for the different branches, so you can go ahead and have inline in one while using WCCP in another one.
Daniel
06-18-2012 06:19 AM
Hi Mohit,
You can run inline at HQ and WCCP at branch office. The goal is to intercept traffic on both side. Thanks
Sent from my iPhone
06-15-2012 06:13 AM
Hi Mohit,
Daniel
06-18-2012 06:19 AM
Hi Mohit,
Sent from my iPhone
