Warning message
ASA 5510 RDP Problem!
Jun 14th, 2012
hi,
Im trying to troubleshoot an ASA 5510 8.3 set up in routed mode providing NAT and IPSEC remote access for a site.
the problem i'm facing is when we try to RDP from the Vpn tunnel users 192.168.9.0/24 to the inside network 192.168.0.0/24 the connection hangs for a while and the we get an error on RDP.
RDP works locally, I also enabled telnet on the machine i'm trying to RDP to and it also fails I wanted to telnet adding the RDP port.
other traffic like windows shares, ping, http, skinny, all work fine and split tunneling is enabled. I can even control asdm from the VPN connection
I tried Nat exemption (old nat 0) from inside to VPN
reduced MTU outside to 1300/1260/1100,
sysopt connection tcp-mss (same above values)
df bit clear
timeout 0:0:0
crypto isakmp nat-transversal 20
and nothing seems to fix it.
also when i run asdm packet tracer source VPN IP dest inside IP with tcp port 3389 the flows completes but it drops the packet after the las Vpn step with a IPSec spoof detected error???
i'm starting to think that the tcp SYN packet is taking the wrong path back to the VPN user with all those Nat rules in the config.
has anyone experienced this?? help is appreciated
here is the config (Alert!! I found a lot of NAT and network objects garbage in there "BUT" everything needed for the VPN user works except of course for RDP I wonder if it has something to do with the issue)
interface Ethernet0/0
nameif outside
security-level 0
ip address X.X.X.X 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.0.48 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
management-only
boot config disk0:/.p
ftp mode passive
dns server-group DefaultDNS
domain-name clubqc.local
dns server-group defaultdns
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
description obj_XXXXXXXX
object network obj_XXXXXXXX
host 6XXXXXXXXX
description XXXXXXXXX
object network NETWORK_OBJ_192.168.7.0_24
subnet 192.168.7.0 255.255.255.0
object network NETWORK_OBJ_192.168.0.0_24
subnet 192.168.0.0 255.255.255.0
object network NETWORK_OBJ_192.168.8.0_29
subnet 192.168.8.0 255.255.255.248
object network NETWORK_OBJ_192.168.8.8_29
subnet 192.168.8.8 255.255.255.248
object network NETWORK_OBJ_192.168.8.16_29
subnet 192.168.8.16 255.255.255.248
object network NETWORK_OBJ_192.168.8.24_29
subnet 192.168.8.24 255.255.255.248
object network NETWORK_OBJ_192.168.8.32_29
subnet 192.168.8.32 255.255.255.248
object network NETWORK_OBJ_192.168.8.40_29
subnet 192.168.8.40 255.255.255.248
object network NETWORK_OBJ_192.168.8.48_29
subnet 192.168.8.48 255.255.255.248
object network NETWORK_OBJ_192.168.8.56_29
subnet 192.168.8.56 255.255.255.248
object network NETWORK_OBJ_192.168.8.64_29
subnet 192.168.8.64 255.255.255.248
object network NETWORK_OBJ_192.168.8.72_29
subnet 192.168.8.72 255.255.255.248
object network obj_192.168.0.3_67_3389
host 192.168.0.3
description 192.168.0.3
object network obj_192.168.0.5_66_3389
host 192.168.0.5
description 192.168.0.5
object network obj_192.168.0.103_66_3389
host 192.168.0.103
description 192.168.0.103
object network obj_192.168.0.10_66_3389
host 192.168.0.10
object network obj_192.168.0.87_66_3389
host 192.168.0.87
description 192.168.0.87
object network obj_192.168.0.205_67_3389
host 192.168.0.205
description 192.168.0.205
object network obj_192.168.0.163_66_443
host 192.168.0.163
description 192.168.0.163
object network obj_192.168.0.253_66_1280
host 192.168.0.253
description 192.168.0.253
object network obj_192.168.0.253_66_5100
host 192.168.0.253
object network obj_192.168.0.253_66_5300
host 192.168.0.253
object network obj_192.168.0.253_67_1280
host 192.168.0.253
object network obj_192.168.0.253_67_5100
host 192.168.0.253
object network obj_192.168.0.253_67_5300
host 192.168.0.253
object network NETWORK_OBJ_192.168.9.0
subnet 192.168.9.0 255.255.255.0
object network NETWORK_OBJ_192.168.8.80_29
subnet 192.168.8.80 255.255.255.248
object network NETWORK_OBJ_192.168.8.0_24
subnet 192.168.8.0 255.255.255.0
object network NETWORK_OBJ_192.168.8.88_29
subnet 192.168.8.88 255.255.255.248
object network abj_XXXXXXXX
host XXXXXXXXXX
object service 3389
service tcp source eq 3389 destination eq 3389
description rdp
object-group service OBJ_OUTSIDE_66_PERMIT tcp
port-object eq 1280
port-object eq 3389
port-object eq 3395
port-object eq 3396
port-object eq 3397
port-object eq 3399
port-object eq 5100
port-object eq 5222
port-object eq 5300
port-object eq https
object-group service OBJ_OUTSIDE_67_PERMIT tcp
port-object eq 1280
port-object eq 3389
port-object eq 3399
port-object eq 5100
port-object eq 5222
port-object eq 5300
access-list outside_access_in extended permit tcp any object-group OBJ_OUTSIDE_66_PERMIT any object-group OBJ_OUTSIDE_66_PERMIT
access-list outside_access_in extended permit ip any any
access-list outside_cryptomap0 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.0 255.255.255.248
access-list outside_cryptomap0 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.0 255.255.255.248
access-list outside_cryptomap0 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.0 255.255.255.248
access-list outside_cryptomap0 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.0 255.255.255.248
access-list outside_cryptomap8 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.8 255.255.255.248
access-list outside_cryptomap8 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.8 255.255.255.248
access-list outside_cryptomap8 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.8 255.255.255.248
access-list outside_cryptomap8 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.8 255.255.255.248
access-list outside_cryptomap16 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.16 255.255.255.248
access-list outside_cryptomap16 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.16 255.255.255.248
access-list outside_cryptomap16 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.16 255.255.255.248
access-list outside_cryptomap16 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.16 255.255.255.248
access-list outside_cryptomap24 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.24 255.255.255.248
access-list outside_cryptomap24 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.24 255.255.255.248
access-list outside_cryptomap24 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.24 255.255.255.248
access-list outside_cryptomap24 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.24 255.255.255.248
access-list outside_cryptomap32 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.32 255.255.255.248
access-list outside_cryptomap32 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.32 255.255.255.248
access-list outside_cryptomap32 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.32 255.255.255.248
access-list outside_cryptomap32 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.32 255.255.255.248
access-list outside_cryptomap40 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.40 255.255.255.248
access-list outside_cryptomap40 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.40 255.255.255.248
access-list outside_cryptomap40 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.40 255.255.255.248
access-list outside_cryptomap40 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.40 255.255.255.248
access-list outside_cryptomap48 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.48 255.255.255.248
access-list outside_cryptomap48 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.48 255.255.255.248
access-list outside_cryptomap48 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.48 255.255.255.248
access-list outside_cryptomap48 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.48 255.255.255.248
access-list outside_cryptomap56 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.56 255.255.255.248
access-list outside_cryptomap56 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.56 255.255.255.248
access-list outside_cryptomap56 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.56 255.255.255.248
access-list outside_cryptomap56 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.56 255.255.255.248
access-list outside_cryptomap64 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.64 255.255.255.248
access-list outside_cryptomap64 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.64 255.255.255.248
access-list outside_cryptomap64 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.64 255.255.255.248
access-list outside_cryptomap64 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.64 255.255.255.248
access-list outside_cryptomap72 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.72 255.255.255.248
access-list outside_cryptomap72 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.72 255.255.255.248
access-list outside_cryptomap72 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.72 255.255.255.248
access-list outside_cryptomap72 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.72 255.255.255.248
access-list test_splitTunnelAcl standard permit 192.168.9.0 255.255.255.0
access-list test_splitTunnelAcl standard permit 192.168.0.0 255.255.255.0
access-list test_splitTunnelAcl standard permit 192.168.7.0 255.255.255.0
access-list test_splitTunnelAcl standard permit 192.168.8.0 255.255.255.0
access-list lan-in extended permit ip any any
access-list outside_cryptomap80 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.80 255.255.255.248
access-list outside_cryptomap80 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.80 255.255.255.248
access-list outside_cryptomap80 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.80 255.255.255.248
access-list outside_cryptomap80 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.80 255.255.255.248
access-list outside_cryptomap88 extended permit ip 192.168.0.0 255.255.255.0 192.168.8.88 255.255.255.248
access-list outside_cryptomap88 extended permit ip 192.168.7.0 255.255.255.0 192.168.8.88 255.255.255.248
access-list outside_cryptomap88 extended permit ip 192.168.9.0 255.255.255.0 192.168.8.88 255.255.255.248
access-list outside_cryptomap88 extended permit ip 192.168.8.0 255.255.255.0 192.168.8.88 255.255.255.248
access-list DefaultACL_vpn extended permit ip 192.168.7.0 255.255.255.0 any
access-list DefaultACL_vpn extended permit ip 192.168.8.0 255.255.255.0 any
access-list DefaultACL_vpn extended permit ip 192.168.0.0 255.255.255.0 any
access-list DefaultACL_vpn extended permit ip 192.168.9.0 255.255.255.0 any
access-list DefaultACL_vpn extended permit tcp 192.168.9.0 255.255.255.0 eq 3389 192.168.0.0 255.255.255.0 eq 3389
access-list DefaultACL_vpn extended permit tcp 192.168.0.0 255.255.255.0 eq 3389 192.168.9.0 255.255.255.0 eq 3389
access-list DefaultACL_vpn extended permit tcp interface outside eq 3389 192.168.0.0 255.255.255.0 eq 3389
access-list global_access extended permit ip any any
access-list global_access extended permit tcp any object-group OBJ_OUTSIDE_66_PERMIT any object-group OBJ_OUTSIDE_66_PERMIT
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any any object-group OBJ_OUTSIDE_66_PERMIT
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool PoolVPN 192.168.9.100-192.168.9.200 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.0_29 NETWORK_OBJ_192.168.8.0_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.8_29 NETWORK_OBJ_192.168.8.8_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.16_29 NETWORK_OBJ_192.168.8.16_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.24_29 NETWORK_OBJ_192.168.8.24_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.32_29 NETWORK_OBJ_192.168.8.32_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.40_29 NETWORK_OBJ_192.168.8.40_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.48_29 NETWORK_OBJ_192.168.8.48_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.56_29 NETWORK_OBJ_192.168.8.56_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.64_29 NETWORK_OBJ_192.168.8.64_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.72_29 NETWORK_OBJ_192.168.8.72_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.0_29 NETWORK_OBJ_192.168.8.0_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.8_29 NETWORK_OBJ_192.168.8.8_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.16_29 NETWORK_OBJ_192.168.8.16_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.24_29 NETWORK_OBJ_192.168.8.24_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.32_29 NETWORK_OBJ_192.168.8.32_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.40_29 NETWORK_OBJ_192.168.8.40_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.48_29 NETWORK_OBJ_192.168.8.48_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.56_29 NETWORK_OBJ_192.168.8.56_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.64_29 NETWORK_OBJ_192.168.8.64_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.72_29 NETWORK_OBJ_192.168.8.72_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.80_29 NETWORK_OBJ_192.168.8.80_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.80_29 NETWORK_OBJ_192.168.8.80_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.80_29 NETWORK_OBJ_192.168.8.80_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.80_29 NETWORK_OBJ_192.168.8.80_29
nat (inside,outside) source static NETWORK_OBJ_192.168.7.0_24 NETWORK_OBJ_192.168.7.0_24 destination static NETWORK_OBJ_192.168.8.88_29 NETWORK_OBJ_192.168.8.88_29
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_192.168.8.88_29 NETWORK_OBJ_192.168.8.88_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.88_29 NETWORK_OBJ_192.168.8.88_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.88_29 NETWORK_OBJ_192.168.8.88_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.0_29 NETWORK_OBJ_192.168.8.0_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.0_29 NETWORK_OBJ_192.168.8.0_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.8_29 NETWORK_OBJ_192.168.8.8_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.8_29 NETWORK_OBJ_192.168.8.8_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.16_29 NETWORK_OBJ_192.168.8.16_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.24_29 NETWORK_OBJ_192.168.8.24_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.24_29 NETWORK_OBJ_192.168.8.24_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.32_29 NETWORK_OBJ_192.168.8.32_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.32_29 NETWORK_OBJ_192.168.8.32_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.40_29 NETWORK_OBJ_192.168.8.40_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.40_29 NETWORK_OBJ_192.168.8.40_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.48_29 NETWORK_OBJ_192.168.8.48_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.48_29 NETWORK_OBJ_192.168.8.48_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.56_29 NETWORK_OBJ_192.168.8.56_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.56_29 NETWORK_OBJ_192.168.8.56_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.64_29 NETWORK_OBJ_192.168.8.64_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.64_29 NETWORK_OBJ_192.168.8.64_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.72_29 NETWORK_OBJ_192.168.8.72_29
nat (outside,outside) source static NETWORK_OBJ_192.168.9.0 NETWORK_OBJ_192.168.9.0 destination static NETWORK_OBJ_192.168.8.72_29 NETWORK_OBJ_192.168.8.72_29
nat (outside,outside) source static NETWORK_OBJ_192.168.8.0_24 NETWORK_OBJ_192.168.8.0_24 destination static NETWORK_OBJ_192.168.8.16_29 NETWORK_OBJ_192.168.8.16_29
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp 3389 3389
nat (inside,outside) static interface service tcp 3389 3397
nat (inside,outside) static interface service tcp 3389 3399
nat (inside,outside) static interface service tcp 3389 3395
nat (inside,outside) static interface service tcp https https
nat (inside,outside) static interface service tcp 1280 1280
nat (inside,outside) static interface service tcp 5100 5100
nat (inside,outside) static interface service tcp 5300 5300
object network abj_69.70.27.66
nat (outside,inside) static obj_192.168.0.5_66_3389 service tcp 3389 3389
nat (inside,inside) after-auto source static any abj_69.70.27.66 destination static abj_69.70.27.66 obj_192.168.0.5_66_3389 service 3389 3389
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group global_access global
route outside 0.0.0.0 0.0.0.0 XXXXXXXX 1
route inside 192.168.7.0 255.255.255.0 192.168.0.150 1
route outside 0.0.0.0 0.0.0.0 192.168.0.150 tunneled
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server RADIUSCPD protocol radius
aaa-server RADIUSCPD (inside) host 192.168.0.19
key *****
radius-common-pw *****
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.0.0 255.255.255.255 inside
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
http 192.168.0.48 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map L2L_map 10 match address outside_cryptomap0
crypto dynamic-map L2L_map 10 set pfs
crypto dynamic-map L2L_map 10 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 10 set reverse-route
crypto dynamic-map L2L_map 20 match address outside_cryptomap8
crypto dynamic-map L2L_map 20 set pfs
crypto dynamic-map L2L_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 20 set reverse-route
crypto dynamic-map L2L_map 30 match address outside_cryptomap16
crypto dynamic-map L2L_map 30 set pfs
crypto dynamic-map L2L_map 30 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 30 set reverse-route
crypto dynamic-map L2L_map 40 match address outside_cryptomap24
crypto dynamic-map L2L_map 40 set pfs
crypto dynamic-map L2L_map 40 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 40 set reverse-route
crypto dynamic-map L2L_map 50 match address outside_cryptomap32
crypto dynamic-map L2L_map 50 set pfs
crypto dynamic-map L2L_map 50 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 50 set reverse-route
crypto dynamic-map L2L_map 60 match address outside_cryptomap40
crypto dynamic-map L2L_map 60 set pfs
crypto dynamic-map L2L_map 60 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 60 set reverse-route
crypto dynamic-map L2L_map 70 match address outside_cryptomap48
crypto dynamic-map L2L_map 70 set pfs
crypto dynamic-map L2L_map 70 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 70 set reverse-route
crypto dynamic-map L2L_map 80 match address outside_cryptomap56
crypto dynamic-map L2L_map 80 set pfs
crypto dynamic-map L2L_map 80 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 80 set reverse-route
crypto dynamic-map L2L_map 90 match address outside_cryptomap64
crypto dynamic-map L2L_map 90 set pfs
crypto dynamic-map L2L_map 90 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 90 set reverse-route
crypto dynamic-map L2L_map 100 match address outside_cryptomap72
crypto dynamic-map L2L_map 100 set pfs
crypto dynamic-map L2L_map 100 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 100 set reverse-route
crypto dynamic-map L2L_map 110 match address outside_cryptomap80
crypto dynamic-map L2L_map 110 set pfs
crypto dynamic-map L2L_map 110 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 110 set reverse-route
crypto dynamic-map L2L_map 120 match address outside_cryptomap88
crypto dynamic-map L2L_map 120 set pfs
crypto dynamic-map L2L_map 120 set transform-set ESP-3DES-SHA
crypto dynamic-map L2L_map 120 set reverse-route
crypto dynamic-map RA_map 65535 set transform-set ESP-3DES-SHA
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map vpnmap 10 ipsec-isakmp dynamic L2L_map
crypto map vpnmap 65535 ipsec-isakmp dynamic RA_map
crypto map vpnmap interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto isakmp enable outside
crypto isakmp enable inside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
vpn-sessiondb max-session-limit 100
telnet 192.168.9.0 255.255.255.0 inside
telnet 192.168.7.0 255.255.255.0 inside
telnet 192.168.0.0 255.255.255.0 inside
telnet 192.168.0.0 255.255.0.0 inside
telnet timeout 20
ssh 198.235.69.156 255.255.255.255 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 20
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc image disk0:/anyconnect-win-2.4.1012-k9.pkg 1
svc enable
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol webvpn
group-policy clubqc_vpn internal
group-policy clubqc_vpn attributes
dns-server value 192.168.0.10 192.168.0.11
vpn-tunnel-protocol IPSec l2tp-ipsec svc
split-tunnel-policy tunnelspecified
split-tunnel-network-list value DefaultACL_vpn
client-access-rule none
webvpn
svc firewall-rule client-interface public none
svc firewall-rule client-interface private none
username bell password """" encrypted
username dmichel password """" encrypted
username coordo_clubqc password """" encrypted
username amine password """"" encrypted
username clubqc_vpn password """" encrypted
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *****
tunnel-group clubqc_vpn type remote-access
tunnel-group clubqc_vpn general-attributes
address-pool PoolVPN
authentication-server-group RADIUSCPD LOCAL
default-group-policy clubqc_vpn
tunnel-group clubqc_vpn ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect pptp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http
https://tools.cisco.com/its/service/odd ... DCEService
destination address email
[email protected]
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
