Warning message
Cisco 2811 Router - Need Help W/ Basic Configuration
Jun 16th, 2012
Hello everyone, I've followed a few guides online to try and set up my router. I would like to use the two FastEthernet ports available on the 2811 for my network. I want to use one for my outside Ip address coming from the ISP and the other for my LAN to hand out Ips to the devices on my network.
With my current configuration, I still cannot connect to the internet when I plug my computer into my LAN port.
Here is my current configuration (sh running-config cmd)
Current configuration : 1565 bytes
version 12.4
hostname USCORRTRCCA01R
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
enable secret 5 $1$ZBd9$QJjb9Oi6wKrHPyAYcnsq2.
enable password chpm7612
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp pool LAN
network 192.168.15.0 255.255.255.0
default-router xx.xx.87.2
dns-server xx.x.224.17 xx.x.224.18
no ip domain lookup
voice-card 0
no dspfarm
archive
log config
hidekeys
interface FastEthernet0/0
description ***LAN***
ip address 192.168.15.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description ***INTERNET***
ip address xx.xx.87.2 255.255.255.248
ip nat outside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xx.xx.87.3
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 1 permit 0.0.0.1 255.255.255.0
access-list 1 permit 192.168.15.0 0.0.0.255
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
access-class 1 in
password chadmin83
login
scheduler allocate 20000 1000
end
ANY HELP IS GREATLY APPRECIATED!!
P.S. I x'd out parts of my ip for privacy, incase you were wondering
John Blakley Sat, 06/16/2012 - 19:19
  • Purple, 4500 points or more
Michael,
The dhcp scope needs to hand out your internal interface as the default-router. So, change that to 192.168.15.1. Aside from that, I'd change the access-list 1 to just "access-list 1 permit 192.168.15.0 0.0.0.255" and get rid of all of the other stuff that you have in there. Also, you probably should remove "ip route 0.0.0.0 0.0.0.0 dhcp" and let your .3 be your default gateway.
Oh, and I'm going to throw this out there, but if you're connecting your computer directly to fa0/1 you're going to need a crossover cable to get a connection.
HTH,
John
mikewestpcs Sat, 06/16/2012 - 19:38
Thanks so much for your help. A few questions, by dhcp scope, what do you mean? I apologize for my networking noobiness . Do you know a command to delete the rest of the "accest-list 1 permit" commands? Also, how do I "let my .3 be my default gateway" Is there a command for it? And yes, I have a crossover cable ready to go.
Again, I truly do appreciate your help so much, I've been trying to get this working for days!
tmalle001 Sat, 06/16/2012 - 19:54
Michael,
As John stated, please do this -
config t
no ip route 0.0.0.0 0.0.0.0 dhcp
ip dhcp pool LAN
no default-router xx.xx.87.2
default-router 192.168.15.1
exit
no access-list 1 permit 0.0.0.0 255.255.255.0
no access-list 1 permit 0.0.0.1 255.255.255.0
CTRL^Z
mikewestpcs Sat, 06/16/2012 - 19:58
Done. Rebooting the router now, and I'll let you know how everything works.
Thanks!
mikewestpcs Sat, 06/16/2012 - 20:11
Alright, I made all the changes, and still no internet access.
Here is my new configuration:
Current configuration : 1384 bytes
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
ip dhcp pool LAN
   dns-server xx.xx.224.17 xx.xx.224.18
no ip domain lookup
voice-card 0
no dspfarm
archive
log config
  hidekeys
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
ip route 0.0.0.0 0.0.0.0 192.168.15.3
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
access-class 1 in
password chadmin83
login
end
tmalle001 Mon, 06/18/2012 - 06:19
Your ip route statement is wrong.
Do this -
No ip route previous statement ...
Ip route 0.0.0.0 0.0.0.0 fa0/1 x.x.87.3
-Tos
tmalle001 Sat, 06/16/2012 - 20:27
No ip route 0.0.0.0 0.0.0.0 192.168.15.3
ip route 0.0.0.0 0.0.0.0 fa0/1 x.x.87.3
(point your default route to outside interface)
mikewestpcs Sat, 06/16/2012 - 20:45
Hmmm, still nothing !
Again, heres the current config:
Current configuration : 1412 bytes
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
ip dhcp pool LAN
   dns-server 66.7.224.17 66.7.224.18
   default-router 192.168.15.1 255.255.255.0
no ip domain lookup
voice-card 0
no dspfarm
archive
log config
  hidekeys
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 xx.xx.87.3
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
access-class 1 in
password chadmin83
login
end
And by the way, I really appreciate your time! Your a HUGE help!
ryates_presido Sat, 06/16/2012 - 21:08
Need to add back your nat acle
Access list 1 permit 192.168.15.0 0.0.0.255
Then try.
mikewestpcs Sun, 06/17/2012 - 09:14
OK, unfortunately, I won't be back to the office until Monday, so I'll have to wait until then to try it. I'll let you know!
Thanks!
mikewestpcs Tue, 06/19/2012 - 16:10
Still nothing! I don't know whats up with this thing. I added my access list back. See anything else wrong...?
Current configuration : 1456 bytes
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
ip dhcp pool LAN
no ip domain lookup
voice-card 0
no dspfarm
archive
log config
  hidekeys
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
access-class 1 in
password chadmin83
login
end
mikewestpcs Tue, 06/19/2012 - 17:01
I'm going to add a few pictures of my current network setup, this way you guys know what Im working with, and can make sure im not missing any information in my router configuration...
My T1 ^^^^
This is what my ISP brought in, I guess it would be considered a modem. ^^^
The 2811 Router ^^^
Two Fast Ethernet ports on the back (this is what im using, crossover cable into 0/1 from my mode, then a normal ethernet cable to my computer. After I confirm it works  on the computer, it will be going into my 2 switches.
Not sure what this is honestly, a serial port?
I'm guessing this is where my T1 is supposed to go, but I'm not using it in my setup.
My Two switches ^^^
This is what the guy from my ISP told me to plug my router into. It's on the modem he setup.
Thanks everyone for the help...
