"show environment temperature"
Answered Question
Jun 17th, 2012
The output I'm getting from my 4506 doesn't match the command output documented in the command lookup tool.  I'm seeing:
B31450604#sh env temp
Module Sensor                     Temperature          Status
1      air inlet                  38C (51C,65C,68C)              ok
1      air outlet                 50C (69C,83C,86C)              ok
2      air inlet                  35C (45C,60C,70C)              ok
2      air outlet                 45C (61C,76C,86C)              ok
3      air inlet                  34C (45C,60C,70C)              ok
3      air outlet                 42C (61C,76C,86C)              ok
4      air inlet                  35C (45C,60C,70C)              ok
4      air outlet                 45C (61C,76C,86C)              ok
5      air inlet                  35C (45C,60C,70C)              ok
5      air outlet                 44C (61C,76C,86C)              ok
6      air inlet                  36C (45C,60C,70C)              ok
6      air outlet                 43C (61C,76C,86C)              ok
What I don't see in the documentation is the meaning of the values within the parentheses.
Would I be wrong to think that it's historical data?
If it is, what's the interval?
Correct Answer by handoko wiyanto about 4 years 7 months ago
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/configuration/pwr_envr.html
check on "Conditions on Supervisor Engine 6-E "
it says ... These linecards support three thresholds: warning, critical, and shutdown.
Overall Rating: 5 (1 ratings)
soroushm Mon, 06/18/2012 - 20:01
I believe what you see in parentheses are: (Normal Temp, Over Temp Threshold, Critical Temp Threshold)
plz Rate if it helped.
Soroush.
Related Content
