Warning message
How do I overcome the fact that not all HTTP requests require redirection
Answered Question
Jun 17th, 2012
  • Silver, 250 points or more
                   I have the following scenario, The Business require that the main login to JDE is just http://prod.apps, I use a redirect server to change it to
http://prod.apps:12001/prod/Mainmanu.maf  so that all works well , but reports and approvals generate links with URIs so the redirect does not work. To overcome this problem I have generated another context with a different VIP without a redirect server and that seems to work ok. But the apllication programmers have to ensure that any reports etc point to this new VIP.
Is there a better  way of doing this?
Correct Answer by Borys Berlog about 5 years 2 months ago
You may  use L7 http class map and add additional matching by GET field in url request (as one possibility). E.g.
currently you have something like this :
policy-map type load first NAME
class class-default
serverfarm
you may add something like this :
class type http load match-any
match http url
then your L7 map will look like :
class
serverfarm
class class-default
serverfarm
More information you can find here :
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_2_0/configuration/slb/guide/classlb.html#wp1021430
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_2_0/configuration/slb/guide/classlb.html#wp1021388
I think it should allow you to have only one VIP for this application. Please try - if you don't succeed, please post URL you use to access reports/approvals links.
If this answer resolved your problem - please mark it as correct it will help to keep our forum more organized.
Thank you.
Overall Rating: 5 (1 ratings)
Correct Answer
Borys Berlog Sun, 06/17/2012 - 23:18
  • Cisco Employee,
class class-default
serverfarm
match http url
class
serverfarm
class class-default
serverfarm
Thank you.
Richard Bradfield Mon, 06/18/2012 - 01:02
Borys,
looks like you got me on the right track, The business just wanted to have a simple link to JDE,
I'll have a play with a test setup later, and let you know how I go
thanks for your help
Richard Bradfield Mon, 06/18/2012 - 17:36
Borys, thanks for your help seems to be working ok, thoughIi will need to do further testing before goes into the production Context.
I do get the following system log messages though when I connect
%ACE-3-400001 MSS mismatch from 172.16.5.185:12001 (1460) to 172.16.10.25:49591(1260) on interface vlan171
I am running A4(2.1) on the ACE and there is a fix in later releases for this, also I am conecting thru a VPN so that might mean the MSS is less on the client. I see what it is like when I am in the office tomorrow.
