Warning message
dhcp proxy vs relay
Endorsed Question
Jun 18th, 2012
What is the difference between dhcp relay and dhcp proxy with respect to ASAs?
Kashish
Cisco Endorsed by Odetayo Adelabu
Ramraj Sivagnan... about 5 years 1 month ago
Hi Bro
DHCP relay listens to local broadcast messages from PC, and forwards these messages on another network towards the DHCP server. The DHCP server responds, and the replies is then forwarded back to the PC.
DHCP proxy is a fully-functional DHCP server and client built inside. The PC establishes IP leases from the DHCP server on one interface, and then keeps these addresses in a pool. On another interface, the server side of the implementation provides leases to other machines using that pool.
Cisco PIX/ASA Firewalls supports both method. In many of my previous implementations, the FW interface on which it behaves as a DHCP server has a dedicated, manually-configured address pool, and the only thing the proxy feature does is get configuration parameters from another upstream server e.g. equipment configuration, as shown below;
Router(config)#boot ?
  bootstrap  Bootstrap image file
  config     Configuration file
  host       Router-specific config file
  network    Network-wide config file
  system     System image file
P/S: If you think this comment was helpful, please do rate it nicely :-)
Overall Rating: 5 (1 ratings)
Ramraj Sivagnan... Mon, 07/16/2012 - 03:19
  • Silver, 250 points or more
Hi Bro
Related Content
