Cannot add SIP command
Jun 18th, 2012
  • Silver, 250 points or more
I have a 2811 router with c2800nm-adventerprisek9-mz.124-24.T4.bin IOS
I amtrying to add the command:
"bind media source-interface loopback 1" and "bind control source-interface loopback 1"
I am can apply these commands but, but in the show run, I never see them.
We tried another IOS, we tried to bind to another interface, but it just won't show these commands.
Erase flash: format flash: nothinh helps.
Any idea?
Jan
Overall Rating: 5 (2 ratings)
Gordon Ross Mon, 06/18/2012 - 02:53
  • Blue, 1500 points or more
Can you post your boxes configuration ?
GTG
j.huizinga Mon, 06/18/2012 - 03:04
hI,
This is the simple configuration:
version 12.4
hostname VOIP
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
fax protocol pass-through g711alaw
h323
sip
  rel1xx disable
voice-card 0
dspfarm
dsp services dspfarm
archive
log config
  hidekeys
interface Loopback1
ip address 80.80.80.80 255.255.255.255
interface FastEthernet0/0
ip address 172.16.0.220 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.0.1
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Under sip we can see and type the bind commands, but we don't see them in the runing config.
This is a simple config, because I have taken the router out of the rack and brought to the lab.
Jan
Gordon Ross Mon, 06/18/2012 - 03:35
Sorry, I've got nothing insightful to offer.
One *very* silly thing to try, is "Loopback1" rather than "loopback1" (Yes, the case is important)
Maybe someone else can chime in with suggestions.
GTG
j.huizinga Thu, 06/21/2012 - 02:18
mmm
Aperantly for the "sip bind" commands to work you have to add:
sccp local FastEthernet0/0
sccp
Don't really get it why, but at least it works.
Jan
Gordon Ross Thu, 06/21/2012 - 02:22
Weird - my 2900 doesn't need that !
How did you stumble upon that ?
GTG
j.huizinga Thu, 06/21/2012 - 02:33
I am using a 2811
I saw that I could apply this command on another 2811, so I got exactly the same IOS on my router.
Still nothing.
Finally I took the whole configuration removed stuff from which I was sure that it has nothing to do with SIP (routes access-lists etc) and then from what was left I added line by line till I saw the bind commands.
This happens to be the SCCP commands.
What has SCCP to do with SIP? I don't know.
Jan
Gordon Ross Thu, 06/21/2012 - 02:35
SCCP has nothing to do with SIP. I'm as confused as you are !
GTG
acampbell Thu, 06/21/2012 - 04:33
  • Green, 3000 points or more
Guys,
The correct syntax to add the bindings should be :-
voice service voip
sip
bind control source-interface loop 1
bind media source-interface loop 1
Works every time for me on a 3845
Alex.
Please rate useful posts.
j.huizinga Thu, 06/21/2012 - 04:54
I have applied these command a zillion times
With different IOS's, and not once I did see the bind command.
Here are some IOS's I tried:
c2800nm-adventerprisek9-mz.124-15.T9.bin
c2800nm-adventerprisek9-mz.124-20.T6.bin
c2800nm-adventerprisek9-mz.124-24.T5.bin
c2800nm-adventerprisek9-mz.124-24.T7.bin
c2800nm-advipservicesk9-mz.124-15.T11.bin
c2800nm-ipvoice_ivs-mz.124-20.T6.bin
All with 2811
Jan
acampbell Thu, 06/21/2012 - 05:48
Jan,
Looks like an unresolved bug
CSCsg68896
CSCsg68896 Bug Details
unable to bind sip protocol to interface
Symptom:
configured binding to interfaces for the sip protocol not visible on the show run
Conditions:
A regular configuration under voice services voip --> sip
Workaround:
none
Further Problem Description:
Status Status
Open
(Assigned)
Severity Severity
4 - minor
Last Modified Last Modified
Any Time
Product Product
Cisco IOS software
Technology Technology
IP Telephony/Voice over IP (VoIP)
1st Found-In 1st Found-in
12.4M
Component(s) Component
Alex.
Gordon Ross Thu, 06/21/2012 - 05:51
Grrr. How did you find that, Alex ? I tried searching BugTrack didn't find that bug.
GTG
acampbell Thu, 06/21/2012 - 05:56
Hi Gordon,
Hope you are well.
I used the new beta bug tool
Tried a search for SIP BIND and bingo !!!
I prefer the text in the original bug tool so I just pasted the BUD ID in there.
Still- they could do with updating the bug itself to explain which IOS are affected and which are fixed.
Life is never perfect unless your lying on the sand under the sun with a cool one
Not that we get much of that here in Scotland
Alex.
j.huizinga Fri, 06/22/2012 - 00:05
That seems to be the issue.
But still, you don't see it in the show run, but it works, or you don't see it and it doesn't work.
If it is the last one, then this is really not a minor bug!
Thanks for all the help!
Jan
Related Content
