Is my router 3845, is hardware prepared for an E1 PSTN Link?
Answered Question
Jun 18th, 2012
Hi All
The IT department in one branch office is planning to connect one of the PSTN links from the Lecagy PBX to the VoIP Router, I would like to know people if my VoIP router is hardware prepared for that change. (I already know's the configuration).
Here is some information:
controller E1 0/0/0
framing NO-CRC4
channel-group 0 timeslots 1-31
description VPN Telmex
controller E1 0/0/1
framing NO-CRC4
clock source internal
description VPN Telmex-2
controller E1 0/1/0
framing NO-CRC4
clock source free-running
pri-group timeslots 1-31
description Enlace Conmutador Loop 12
controller E1 0/1/1
framing NO-CRC4
description Enlace Conmutador Loop 41
controller E1 0/2/0
shutdown
framing NO-CRC4
controller E1 0/2/1
shutdown
framing NO-CRC4
controller E1 4/0
shutdown
framing NO-CRC4
controller E1 4/1
shutdown
framing NO-CRC4
NAME: "3845 chassis", DESCR: "3845 chassis"
PID: CISCO3845         , VID: V01 ,
NAME: "c3845 Motherboard with Gigabit Ethernet", DESCR: "c3845 Motherboard with Gigabit Ethernet"
PID: CISCO3845-MB      , VID: V03
NAME: "Two port E1 voice interface daughtercard", DESCR: "Two port E1 voice interface daughtercard"
PID: VWIC-2MFT-E1=     , VID: 1.0,
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 ,
NAME: "2nd generation four port FXO voice interface daughtercard", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 ,
NAME: "PVDMII DSP SIMM with four DSPs", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: NA  ,
NAME: "High Density Voice2 Network module with on board two port interface ", DESCR: "High Density Voice2 Network module with on board two port interface "
PID: NM-HDV2-2T1/E1    , VID: V05 ,
PID: PVDM2-64          , VID: V01 ,
PID: NM-HDV2-2T1/E1    , VID: V04 ,
NAME: "PVDMII DSP SIMM with three DSPs", DESCR: "PVDMII DSP SIMM with three DSPs"
PID: PVDM2-48          , VID: V01 ,
NAME: "PVDMII DSP SIMM with one DSP with half channel capcity", DESCR: "PVDMII DSP SIMM with one DSP with half channel capcity"
PID: PVDM2-8           , VID: V01 ,
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(25c), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 12-Feb-10 03:18 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
System image file is "flash:c3845-spservicesk9-mz.124-25c.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3845 (revision 1.0) with 743424K/43008K bytes of memory.
Processor board ID FTX0953C2M9
2 Gigabit Ethernet interfaces
64 Serial interfaces
8 Channelized E1/PRI ports
4 Channelized (E1 or T1)/PRI ports
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Do I have enogh RAM and DSP's?
Do you have an advice for me?
Regards.
troller E1 0/0/0
framing NO-CRC4
controller E1 0/0/1
framing NO-CRC4
controller E1 0/1/0
framing NO-CRC4
controller E1 0/1/1
framing NO-CRC4
controller E1 0/2/0
shutdown
framing NO-CRC4
controller E1 0/2/1
shutdown
framing NO-CRC4
controller E1 4/0
shutdown
framing NO-CRC4
controller E1 4/1
shutdown
framing NO-CRC4
Correct Answer by Aaron Harrison about 5 years 2 months ago
You have lots of hardware.
You should find out what type (physically, e.g. analogue, e1, rj48/45 or bnc) and signalling method (QSIG, DPNSS? PRI?) the PBX will use...
For further advice it's probably best to describe your scenario more fully...
Aaron
Overall Rating: 5 (2 ratings)
etamminga Mon, 06/18/2012 - 14:29
  • Bronze, 100 points or more
You've got plenty of hardware to at least connect 4-8 E1s
Erik
Correct Answer
Aaron Harrison Mon, 06/18/2012 - 22:30
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Juan Gerardo He... Wed, 08/22/2012 - 07:52
Thanks, it was, It is just I think I needed more DSP's beause I only got 27 TDM ports configureng my E1 cause of the lack of DSP's
Thank you.
Related Content
