Basic Router SSH Access
Michael Reyes
Hello Cisco Experts,
I need to configure a 2921 ISR.  Basic config below.  Nothing elaborate as far as config goes.  Inside traffic routing outside.  GE0/0 - External IP and GE0/1 - Internap IP.  I'm trying to telnet to the GE0/0 interface, but it's not working.  Did I miss something?  This is a brand new router I received this afternoon.  Ultimately I need to enable SSH and restrict access to two remote IP addresses (x.x.x.244 & x.x.x.246)
Any assistance would be greatly appreciated.
Michael
Basic Configuration Below
Current configuration : 5325 bytes
! Last configuration change at 22:47:28 UTC Mon Jun 18 2012 by root
version 15.1
service password-encryption
hostname cv_router_2921
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 *******.
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name corp.local
crypto pki trustpoint TP-self-signed-3184049427
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3184049427
revocation-check none
rsakeypair TP-self-signed-3184049427
crypto pki certificate chain TP-self-signed-3184049427
certificate self-signed 01
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
          quit
license udi pid CISCO2921/K9 sn FGL161612S2
username my_username privilege 15 secret 4 *******
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Transit Network
ip address x.x.x.134 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description Internal Transit Network
ip address x.x.x.225 255.255.255.224
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 x.x.x.133
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
banner exec ^C
% Password expiration warning.
Removed
^C
line con 0
exec-timeout 0 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
password 7 *******
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
password 7 *******
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
cv_router_2921#
        quit
username username privilege 15 secret 4 *******
redundancy
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
banner exec ^C
Removed
^C
line con 0
exec-timeout 0 0
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
password 7 *******
login local
line vty 5 15
access-class 23 in
privilege level 15
password 7 *******
login local
end
cv_router_2921#
Michael
Thanks for the additional explanation. That does help.
Am I correct that the ping problem was just a transposition of octets in the address? Or is there still some problem with pinging?
Rick
Rick
32 Replies 32
John Blakley
Michael,
You'll need to remove the default acl on the line:
line vty 0 4
no access-class 23 in
That'll get you into the router with telnet.
HTH,
John
HTH, John *** Please rate all useful posts ***
Hello John,
Thank you for the post.  I've left for the day and will try that in the am.  Also as mentioned, ultimately, I want to remove telnet and enable ssh with an ACL to the outside interface of the router.  I'm going to review that this evening at home so that I can try out my config when I get into the office in the morning.
I'll let you know how it goes tomorrow,
Michael
additionally to removing the acess-class, you should always configure all vty-lines:
line vty 0 15
xxxx
That way you'l have the same config on all lines and not what is in your config where some lines are enabled for SSH, but some are not. Probably that's not intended?
Regards, Karsten
Hello Karsten,
I found it odd that it showed up that way as I entered the command as you included in your post.  Any idea why that would be?
Michael
sebastian.lemke
Enable *only* SSH on all VTY lines:
conf t
line vty 0 15
transport input ssh
exit
crypto key generate rsa general-keys modulus 1024
The last command is needed to generate a crypto key, which is used in each SSH session.
I'd also recommend setting a new username and enable secret:
username USER privilege 15 secret 0 PASSWORD
enable secret 0 PASSWORD
HI Try this:
Config t
line con 0
login local
line aux 0
line vty 0 4
login local
transport output all
please rate if it helps.
After reviewing posts, I've made recommended changes.  Removing the ACL did no allow me to telnet to the router.  'm taking this one step at a time and will start with telnet access.  Once that's resolved, I'll move on to ssh access, and then finally on to ACLs.
Below is the snipet from the config around the VTY usage.  Any insight into the "line 2" part of the config?  The telnet config is very basic and I've configured telnet on other devices in the past.  Not sure why I'm having difficulty now.
This is how I've set up the devices:
[My Laptop - RJ-45]  --  Cross-Over Cable  -->  [Router E0/0]
xx.xx.xx.133 255.255.255.252                        xx.xx.xx.134 255.255.255.252
[My Laptop - Serial]  --  Serial Cable          -->  [Router Console Port]
line con 0
exec-timeout 0 0
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
password 7 1313030B341E0B3F3F213A616C7042
login local
line vty 5 15
privilege level 15
password 7 06101B38735C060C1112005955567B
login local
end
the "line 2" config is typically used for modules in the router, so that is probably not relevant for this problem.
The "line vty" looks ok. Do you have any interface-ACLs at the moment?
Do you have basic connectivity? I.E. you can ping your router or if not do you see the other device in the ARP-Cache?
And: How far do you get with your test? Telnet-Access can go wrong in multiple ways.
Up until about 5 minutes ago I had console access.  I enter username/password that I created and I am receiving invalid login.
Username: Root
Password:
% Login invalid
Any ideas?  If needed, I'll need to reset to default.
Regarding your other questions:
  • I had my laptop and a spare connected to E0/1 & E0/2 respectively.
  • Each laptop was configured with appropriate IP addresses for the IP addressing information configured on the connected interface.
  • From each laptop, i was able to ping the interfaces on the router as well as to the laptop on the other interface.
Michael
and you configured a username "Root" with a corresponding password or secret?
I configured the following:
username root privilege 15 secret 0 *********
enable secret 0 ********
I just added another discussion regarding my issues with the password recovery procedure.  I need to get that resolved before proceeding with these steps.
Hello Karsten,
I'm back working my telnet/ssh/acl issue.  From my laptop, I am able to ping the interface of the router.  I removed the default ACL
no access-list 23 permit 10.10.10.0 0.0.0.7
Michael
Removing the access list 23 is a good thing. But more important is to make sure that the vty lines no longer have the access-class configured, since that is what actually controls remote access.
Is this still the accurate listing of the config for the vty lines
line vty 0 4
privilege level 15
login local
If this is the configuration then I would expect that telnet to the router address from a connected device should prompt for a user name and password and should authenticate using the user name and password that you have configured on the router. Is that what is happening?
Rick
Rick
Hello Rick,
That is correct.  I found my IP had an incorrect network octet.  I do get prompted for username/password now.
Is there a way to configure a network object to control access.  Here is what I'm trying to figure out.
Create an object called Allowed_SSH_IP
Add x.x.x.224 and x.x.x.246
Configure SSH on the outside interface to only allow IP addresses in this object.
Does that make sense?
Michael
