CUCM application dialing rules
Jun 18th, 2012
Hi All,
When I tried to make an outbound call using CUPC(ver 8), it was failed getting message from call manager that “your call cannot be completed”
All the respective screen shots are attched.
Highly appreciate if someone can throw some lights towards this…
Thank You!
Sanoop
Jaime Valencia Mon, 06/18/2012 - 20:51
  • Cisco Employee,
  • Hall of Fame,
    2011
That message means your CSS/partitions do not allow you to call whatever you're trying to call, adjust them as necessary.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Sanoop N V Tue, 06/19/2012 - 10:26
Java,
     I am facing issue only while dialing thru CUPC. Calls are maturing from the IP Phones without any issues. I felt issue is with dialing rule.
Please advice..
Thank You,
Sanoop
Aaron Harrison Tue, 06/19/2012 - 22:45
  • Community Spotlight Award,
    Member's Choice, May 2015
Did you apply the cop file to generate the TFTP files? This must be done after any change to the dial rules..
Aaron
Related Content
