WRVS4400N Telnet
Genome_666
Hi guys
Is it possible to telnet into the 'WRVS4400N Wireless-N Gigabit Security Router with VPN' router? When I try it says the remote system refused the connection.
linksysinfo
Level 4
Level 4
There is no Telnet/SSH on the vast majority of WRVSx/RVx routers.  you could check OpenWRT to see if anyone has created a 3rd party firmware for it, but i doubt it very much,
Regards Simon
http://www.linksysinfo.org
Regards Simon
5 Replies 5
linksysinfo
Level 4
Level 4
Regards Simon
Regards Simon
Dean Thompson
http://wiki.openwrt.org/toh/cisco/wrvs4400n_v2
It looks like something has been made for it, I may try this on my router to see if it fixes my radio problems.
Pity it doesn't support telnet with the provided firmware.
What radio problems are you having? I'm also having problems with it disconnecting on my macs randomly.
Frequent disconnects of all wireless clients, clients unable to reconnect for minutes after.  Normally after streaming, downloading and such, even browsing the net did it.
Cisco replaced my unit with a new one, of which has worked out great.  I still see diconnects for a key renewel but it reconnects within a second or two.
My issues are resolved now
Lol I had the EXACT same issue. Cisco took back all 8 of them. Now going the aironet way. getting the 1041 and a controller. So excited for it to arrive ^_^
