Warning message
jrabinow Tue, 06/19/2012 - 04:52
  • Cisco Employee,
AFAIK This is not currently supoorted in ISE AFAIK and is a feature planned for ISE 1.2
jrabinow Fri, 06/29/2012 - 08:19
  • Cisco Employee,
Thanks for giving me the chance to check this out further. This is what I found:
The admin interface is restricted to eth0, the guest and sponsor portals can be accessed from all interfaces (so long as they are not running on port 443). There is a firewall rule on port 443 to allow access only from eth0.
steven.vandyk Tue, 07/10/2012 - 02:39
I have tested this, and the portal does work on the other interface, however, I cant login with the guests, Im getting an error about the session cache.
Tarik Admani Tue, 07/10/2012 - 21:28
  • Green, 3000 points or more
Did you see this with an ipad? Try connecting to a webpage that isnt cached on the device itself and try an entirely different website that you havent connect to before. I saw this a few weeks back when i was setting up a POC but the issue never repeated itself once we got it working the first time.
thanks,
Tarik admani
Naveen Kumar Thu, 03/21/2013 - 11:45
  • Silver, 250 points or more
in New release of  ISE 2.0 you can get  the feature. There you can decide the different port for different roles. It  will help to balance the traffic load to ISE.
Related Content
