Warning message
Configuring NCS and ACS 5.0 with AD and tacacs+
Jun 19th, 2012
Hi All
I am trying to get the ACS 5.3 to work with NCS but cannot make it work correctly.
I have looked at this link -
http://www.cisco.com/en/US/products/ps6305/products_tech_note09186a0080b904a4.shtml
But this does not show how the ACS referencing AD groups would work when determining
which   custom attributes to use.
On the ACS 5.3 i have set up the following -
The ad is working and in        Users and identity stores/External identity stores/Active Directory then my AD test works fine.
I have set up the  Users and Identity stores/Identity Groups with appropriate ip s.
I have configured the Network Device Groups/Network Devices and AAA Clients with the ip address and Authenication optionsA
In Policy Elements/Authorisation and Permissions/device administration/shell profiles
I have creeated a shell  profile called network shell pro
which das a common tasks of def priv = 0 and max priv = 15
Custom attributes of the following -
role0     Mandatory         Admin
task7    Mandatory         Administration Menu Access
task69   Mandatory        Home menu access
virtual-domain1   Mandatory  CRUK
task80    Mandatory      License Check
virtual-domain0    Mandatory   ROOT-DOMAIN
IN Access Policies/Access services/Default Device Admin
i have identity and Authorisation ticked -
identity = AD1
Authorisation =
name      AD1:External groups          Compound Condition   NDG:Device Type                          NDG:Location time/date identity group shell profile
Rule-1      ANY                                AD Group                   In all device types:Cisco Prime     Any                   any        any               network shell pro
Now i can get into the NCS but i do not see any of the administration buttons on NCS - so
this means the custom attributes are not working.
Any ideas on why this is not working - i shouldnt need a user for this on the ACS as its using AD !!!
Thanks in Advance
Steve
Scott Fella Tue, 06/19/2012 - 07:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Steve,
For root access via tacacs, there are 100+ attributes you need to enter for the shell profile. You can get that list from the WCS/NCS. Seems like tacacs is working, you just need to define more roles.
http://www.cisco.com/en/US/docs/wireless/ncs/1.0/configuration/guide/adm...
Related Content
Trending Topics - Security & Network
