ASA 5505 Trunk ports
Jun 19th, 2012
t
I need to configure my cisco ASA firewall using trunk ports for connect some switches ( cisco and HP)
each port connected to the switches will use the same security level but with differente IP: example
interface Vlan4
nameif inside4
security-level 100
ip address 10.10.2.1 255.255.255.0
interface Vlan5
nameif inside5
security-level 100
ip address 10.10.3.1 255.255.255.0
interface Vlan6
nameif inside6
security-level 100
ip address 10.10.4.1 255.255.255.0
interface Vlan7
nameif inside7
security-level 100
ip address 10.10.5.1 255.255.255.0
Each port of the firewall will be configured like this:
interface Ethernet0/2
switchport trunk allowed vlan 4 5 6 7
Do i need to allow the native VLAN in the trunks ports or a special tag? because i also need to add a new vlan (vlan 1 for some servers)
I would like to know if i need to add some kind of routing for this in the firewall?,  i know as the firewall will be the layer 3 equipment it will route between the vlan's.
Also, my configuration in the switches should be only a trunk port? do i need to specify a tag for this vlans?
I each switch i will configure the VLAN with IP also ( vlan 4 5 6 7 and vlan 1 ).
Overall Rating: 4 (1 ratings)
Ramraj Sivagnan... Mon, 07/16/2012 - 00:59
  • Silver, 250 points or more
Hi Bro
Please do add these commands in your Firewall, and you should be good.
same-security-traffic permit intra-interface
description ## Link to HP Access Switch (Manageable Switch) ##
switchport mode trunk
switchport trunk allowed vlan 4,5,6,7
Please do ensure you've similar configuration in your HP Access Switch, as well. Yes, the port has to be dot1q trunk.
For further details on this, please do refer to http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807fc191.shtml
P/S: If you think this comment is useful, please do rate it well :-)
Related Content
