processor fan was producing lot of noise and nothing was displaying in monitor
Jun 19th, 2012
hi
recently my call manager was not working.
while it was switching on the processor was continiously producing lot of noise
and t was not displaying nothing on monitor.
no changes was made after sucessfull running from last 5 mnths.
can any one clarify what is the problem.
thanks
regards
praveen kumar gvk
Mark Turpin Fri, 06/22/2012 - 12:03
It sounds like there could be a lot of different things going on with the hardware in particular.
What type of server do you have?
IBM
HP
Cisco UCS
What model is the server?
7815, 7825, etc.
G5, G6, etc.
x-Series, etc.
C/B-series, etc.
Are any of the diagnostic lights on the server lit?
When rebooted/rebooting - are there any messages during the BIOS POST?
PRAVEEN KUMAR GVK Thu, 06/28/2012 - 11:11
hi
thanks for rply
i am having ibm server, model is 7825, the server was noot booting, nothing was displaying in monitor.
1. serever power on but it was not load into the os.
2. pci riser was installed. there is no saparate video slot.
3. monitor was connected to standard vga.
4. in the server bmc heart beat led blinking, standby power led, sas/sata  controller power led is glowing.
5. hard disk drive activity led is glowing continuously.
the problem is server is not booting. nothing was displaying in monotor. all the fans are working fine. i had tried each fan they are all working. i also try to boot with single ram.  but the server was not booting.
PRAVEEN KUMAR GVK Fri, 06/29/2012 - 18:24
hi
thankq for quick rply
there is no other led rather than above mentioned.
the server was not able to boot the os so what will be the problem.
thanks & regards
praveen kumar gvk
Related Content
