CISCO Controller based WLAN
Jun 19th, 2012
     We have implemented  WLAN using Cisco WLAN controller (5508) and AP (AIR-CAP3502E-E-K9), i  am trying to connec AP (which have gigabit port) with Layer 3 switch  using UTP Cat-6 Cable having 24 AWG Wire Gauge.
What maximun length i can achieve by using above mentioned cable??
Noman
Scott Fella Tue, 06/19/2012 - 22:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
100 meters if it's cat5, cat5e, cat6 or cat6e
http://en.m.wikipedia.org/wiki/Category_6_cable#section_3
Leo Laohoo Tue, 06/19/2012 - 22:57
  • Hall of Fame,
    2017 LAN, Wireless
Yup.  100 metres and no more.
Muhammad Noman Wed, 06/20/2012 - 00:03
But in our case we needs the distance of about 180-200 meter, and one more thing we are planning to use POE.
How can we extend the distance??
Noman
irfan dharma Wed, 06/20/2012 - 11:50
Hi Noman,
any cat cable cannot extend more than 100 meters, specally POE , you will need to use a  managed switch with poe to extend cables, you have cut the cable about 100-95 m, then connect the switch then use another cable for remaining length.
i did the same thing for our network
thanks.
Irfan.
