Warning message
access-list with first zeto octet. Is it correct?
Jun 20th, 2012
I have seen config like:
access-list 1 permit 0.21.0.0 255.0.255.255
Can you please let me know if such config is correct and if yes, explain more
Thanks!
Overall Rating: 4 (1 ratings)
Peter Paluch Wed, 06/20/2012 - 03:24
  • Cisco Employee,
This ACL is somewhat bizzare but it is not incorrect per se. It matches all packets whose source IP address has the form
x.21.x.x
where "x" is an arbitrary number (it is totally irrelevant what the value of "x" is).
I do not know what was the intention of the creator of this ACL. Therefore, it is difficult to answer the question if the ACL is correct. Syntactically - sure it is. Semantically - I do not know, that depends on what shall be accomplished with it.
Best regards,
Peter
handoko wiyanto Wed, 06/20/2012 - 04:16
hi webstd.design,
imho,
by reading the way it wrote wildcard mask (255.0.255.255)
that command is wrong.
if we referring to the standard access list for example this is a very old cisco IOS version, (http://www.cisco.com/en/US/docs/ios/11_3/feature/guide/stdlog.html)
the part that we write wilcard mask is by putting 1 to the host bit portion
source-wildcard
(Optional) Wildcard bits to be applied to the source. There are two alternative ways to specify the source wildcard:
Use a 32-bit quantity in four-part, dotted-decimal format. Place ones in the bit positions you want to ignore.
Use the keyword any as an abbreviation for a source and source-wildcard of 0.0.0.0 255.255.255.255.
regards,
webstd.design Wed, 06/20/2012 - 04:21
Looks like it's a question from BGP exam, so should be correct
handoko wiyanto Wed, 06/20/2012 - 04:56
interesting!
would you mind sharing the complete question with the config that you wrote before?
regards,
webstd.design Wed, 06/20/2012 - 05:40
Can you provide something like this as an example? It could be interesting questions for interview
Nandan Mathure Wed, 06/20/2012 - 05:53
  • Bronze, 100 points or more
Hi!
such access lists are used for matching the networks. Here in the example any network with second octet of 21 will be matched.
More examles...
access-list 10 permit 192.168.0.1 0.0.0.0  [matches a host route of 192.168.0.1]
access-list 10 permit 0.16.16.0 255.0.0.255 [ matches any network which has 2nd and 3rd octet of 16]
access-list 10 permit 10.0.0.0 0.0.255.192 [ matched networks 10.0.0.0 to 10.0.255.192]
i would suggest convert wildcard to binary and match the corresponding bits with must match or match any. i.e 0 is must match and 1 is any (in case of wildcards)
let me know if this helps,
Nandan Mathure
