Warning message
webvpn plus ipsec ASA5505
Answered Question
Jun 20th, 2012
Hi All,
I have 2 ipsec tunnel active on ASA5505 (secplus license).
I would like to activate sslvpn also. Is it possible or there are issues in keeping active both services?
Correct Answer by Jennifer Halim about 5 years 2 months ago
Yes you can run both IPSec and SSL VPN tunnels at the same time.
For SSL VPN, it comes with default 2 license, meaning you can have 2 concurrent SSL VPN tunnels.
If you need more, then you would need to purchase the AnyConnect license.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Wed, 06/20/2012 - 04:29
  • Cisco Employee,
crash0verride Wed, 06/20/2012 - 04:50
Could you provide a link with purchase codes?
Jennifer Halim Wed, 06/20/2012 - 04:58
  • Cisco Employee,
There are 2 types of AnyConnect License:
1) AnyConnect Essential: supports the maximum number of full tunnel AnyConnect SSL VPNs.
2) AnyConnect Premium (user base license): supports full tunnel AnyConnect SSL VPN, clientless SSL VPN and advance feature of SSL VPN.
Here is the part# for your refernce:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/overview_c78-527488.html
Related Content
