Warning message
CISCO Unity Express (CUE) greeting question.
Answered Question
Jun 20th, 2012
Is it possible to remove system greeting (i.e. Leave your message after the tone. Finnaly hang up or press # for more option) or rewrite it?
Calling users confuse, then hear two almost same greetings with different voices.
Thanx in advance!
Correct Answer by Rob Huffman about 5 years 1 month ago
Hi there,
You can delete these prompts
voicemail conversation caller recording-prompt
To  enable playing a prompt to a caller to record a message, use the  voicemail conversation caller recording-prompt command in Cisco Unity  Express configuration mode. To disable the prompt, use the no form of  this command.
no voicemail conversation caller recording-prompt
Syntax Description
This command has no arguments or keywords.
Defaults
The default is enabled (the system plays the prompt).
Usage Guidelines
The  caller hears the following message after the recipient's greeting  plays: "Record your message after the tone. When you are finished, hang  up or press # for more options." Use this command to enable or disable  the playing of this prompt.
To  display the status of the caller recording-prompt, use the show  running-config command. If the prompt has been disabled, the following  line appears in the output:
The show running-config output will not display any status of the prompt if the prompt is enabled.
Examples
The following example disables playing the caller record-prompt:
se-10-0-0-0# config t
se-10-0-0-0(config)# no voicemail conversation caller recording-prompt
se-10-0-0-0(config)# end
se-10-0-0-0#
https://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/Command/v_cmds.html#wp1016219
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 06/20/2012 - 05:45
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
Syntax Description
Defaults
Usage Guidelines
Examples
se-10-0-0-0#
Cheers!
Rob
Related Content
