Warning message
Packets not hitting the route-map's NAT access-list
Jun 20th, 2012
Hi Everyone,
I've been struggling with this issue for two days, I have couple of VPN tunnels on a router and all are working fine with NAT because I created route-maps for nat to deny the packets that are going to the tunnel from getting NATed, I have the same config for all the tunnels but the issue is with xxx_NAT access-list that is not even being hit by the packets so my xxx tunnel wont come up. I am positive that the problem is NAT because when I remove NAT from the 0/1.102 interface it starts to work. here is my config :
interface GigabitEthernet0/1.102
description "xxx"
encapsulation dot1Q 102
ip address 10.300.301.1 255.255.255.0
ip access-group xxx_ACL in
ip nat inside
ip virtual-reassembly
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool ???_POOL ??
ip nat pool xxx_POOL ??
ip nat inside source route-map ??? pool ???_POOL overload
ip nat inside source route-map xxx pool xxx_POOL overload
ip access-list extended xxx-VPN
remark VPN to xxx
permit ip 10.300.301.0 0.0.0.255 192.168.45.0 0.0.0.255
permit ip 192.168.45.0 0.0.0.255 10.300.301.0 0.0.0.255
ip access-list extended xxx_ACL
deny   ip 10.300.301.0 0.0.0.255 192.168.56.0 0.0.0.255
permit ip any any
ip access-list extended xxx_NAT
deny   ip 10.300.301.0 0.0.0.255 110.110.2.0 0.0.0.255
deny   ip 10.300.301.0 0.0.0.255 192.168.45.0 0.0.0.255
permit ip 10.300.301.0 0.0.0.255 any
route-map ??? permit 10
match ip address ???_NAT
route-map xxx permit 10
match ip address xxx_NAT
match ip address NAT_???
control-plane
banner motd ^C
Karsten Iwen Wed, 06/20/2012 - 07:25
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
As that is probably *not* the config you are having problems with (or are your route-maps really named ???, xxx etc. ?) it is hard to help.
So just a guess:
The "ip nat inside source route-map-"staements are processed in a lexical order. The naming of your route-maps has to reflect the order you want to achieve. If you have the wrong order your traffic will end in the wrong translation which you should see with "show ip nat translation".
HTH, Karsten
yasaman64 Wed, 06/20/2012 - 07:42
Thank you sooo much Karsten, that was actually the issue, I wouldn't have think of it in a million years lol
